Retrovert
Addicted Member
Before anyone knew better, it was common to use many different materials to coat the surrounds, including stuff like latex and Permatex. DON'T DO THAT. We know better now.
The factory applied a butyl compound to the surrounds and dust cap. RoyC tested many different materials and compounds for surrounds. In every case, using anything other than the same stuff the factory used resulted in worse performance. Many woofers are trashed because the surrounds were coated with stuff that cannot be removed and the woofers no longer performed as they should.
The proper stuff to use is a butyl compound sold by member RoyC and on ebay by vintage-ar. Please do not use any other material.
KLH published Service Bulletin 60 that described applying butyl to the surrounds and to the dust cap for woofers. Bulletin 60 is available at Classic Speaker Pages.
All completely true.
Ignore this truth and the drivers will be destroyed.
