alteclipsch
I think the bulletin said the dust caps, not the cones. I don't have it in front of me but I've not seen anything about doping the cones.
These caps are solely for testing the tweeters while outside of the cabinet and crossover circuit to prevent low frequencies from reaching the tweeter. It does not go into the circuit when you put the tweeters back in.
Good luck with your project!!!
Rock6x, I didn't change the circuit at all, I simply replaced the aging capacitors.
Thanks KJ244 for your reply.I think what specialidiot is referring to is to use a 10uF capacitor in series with the tweeter positive when testing a tweeter outside of the cabinet. This is common bench test technique for checking tweeters. You should replace the caps in your crossover with equivalent capacitor values. For example, in a Model 17, the 8uF capacitor should be replaced with an 8uF or an equivalent - e.g., 4.7uF and 3.3uF in parallel.
)Got it. So that 10 Uf was not part of the original specs and not necessary?The Model 17's are wonderful speakers. I've restored four pairs in accordance with the original specs. I have not found a reason yet to deviate.
FYI: Currently the only caps in these speakers are the 10Uf on the tweeter and (1) 2UF 50v on the circuit board. They play but sound muffled.
The drivers all test good. ( as I mentioned, someone did some mods)
It sounds like a previous owner decided he could do better than the factory and modified the crossover. That is generally a bad idea.
When a vintage speaker sounds muffled, the likely culprit is an old, out-of-spec capacitor.
The crossover should have three caps (2 each 2 uF and one 8 uF), three resistors, and one 3-position switch. I suggest tracing out the crossover and drawing a schematic. At the very least, take pictures and post them here (resize to around 100 to 300 kb first).
Below is the factory crossover schematic for the Model 17. I suggest making your speakers look like the factory intended.
amazing, this string has gone on 10+ years! I found a pair of KLH 17s at the thrift store, $12 each. Grills were spotless, the cabinet pretty bad. I lightly sanded the veneer and what a pleasant surprise! Danish oil plus General Finish’s satin topcoat. Recapped with Dayton 1% caps (used the 8.2 mF). Treated the speaker surrounds, sealed the cabinet. Old 8 mF caps tested at ~9.5, double 2 mFs about 3.5 each.Thanks KJ244 for your reply.
Currently the 17's I just purchased had apparently been previously modified as I discovered when I opened them up.
There's a 10uf on the positive side of the tweeter. Should I just remove that and follow the rest of specialidiots cap replacements?
