replacing "fm stereo" LED on G-7000
FLMike
Banned
I need to replace the red "fm stereo" led on a Sansui G-7000...
The service manual list the part as SG-12C (red) LED
I don't know much about electronics...do LED's have voltage/wattage values?
Led
Yes, they do...typically about 2 volts. But check for voltage with a strong station selected and receiving in stereo at the LED prior to removal, those last forever, could be a differant problem.
Casey
It's not likely the LED is bad. Like Casey said, put a voltmeter across it and look to see if voltage is present when you tune across a strong stereo station.
- Pete
