Resetting all parameters on YAMAHA RX-V430RDS?
hifidel
Hi,
I have a question if anyone can help on this forum about how can I reset all the parameters of YAMAHA RX-V430RDS to the initial factory settings.
Thanks!
There's a specific button combo you have to hit to get into the reset menu. Take a look at the manual for that model on Yamaha's website because the buttons are slightly different depending on the model. Standby and Straight are a common combo.
Thank you Nightwisher! I have the owner’s manual and it seems like the resetting all parameters option is not listed there. This specific model doesn’t have the straight (effect) button.
If I recall correctly, the menu you want is the "advanced settings" menu. It's the same menu to switch from an 8 ohm setting to 6 (or whatever the model allows) on the Yamahas I have encountered.
I wonder if it's standby and stereo effect on that model?
The option is called "INIT-ALL" (at least on later models).
I found that for this specific model you have to press STANDBY/ON while pressing INPUT MODE and A/B/C/D/E simultaneously to enter "advanced settings" menu.
