Well I did reflow those joints and also check the FG coil for continuity and looks fine, but I have my doubts, I don't know if maybe to check it for continuity is not enough. I will remove all the motor assembly to inspect very carefully visually just in case, but I already de-solder the joints and checked the FG coil disconnected from the board and seams OK.
Another thing that intrigued me is that the AC coming out from the transformer to the retifier is 60 VAC not 30VAC as one of the schematics states. Someone knows about a unit using a 60VAC transformer or could be that this one here is also not original?
The transformer is connected to 120VAC so this is not the case.the transformer is either wired for the wrong input voltage or it's a 120VAC transformer and your feeding it 240VAC.
I would check that little coil for resistance before anything else. If it's shorted (which it seems it is) it will show a lower value than the rest. Next, I would just rewind the coil instead of getting another entire assembly. Can't be that hard even though it is small. Measure the wire gauge count the turns when unwinding the old one and take note which way the winding goes and which way you install it. This is important.
I would also check the large coils as well, just as a matter of course.
Those transistors you're chasing don't need to be changed if they measure well. But if you do want to change them, they are nothing special, you can replace them with any similar modern equivalents.
But I don't think the transistors are the problem.
Chase up the transformer problem and see what's up with that.
Fix the problem with the coil and see what happens before you venture further.
If problems persist, I would have a look at the ICs. If these don't do their job properly, you will never get the motor to work properly. And again, those ICs are nothing special, modern equivalents should be readily available and drop straight in.
Have seen where people sanded the paint of the aluminum wet sanded the aluminum with 600 grit and bugged out to a polished finish and bought new control stencils looked really cool they also make covers of different collars or chrome finish that goes on the turn table lots of cool stuff for those ! I have the pl120 Chinese knock off of that table ! While not as durable it performs pretty decent ! Have a sumiko pearl cartridge I put on a definite inprovement ! Over the stock cartridge ,Hello friends,
Some months ago I was bitten by the idea of buying a turntable and to start a record collection. My first choices were mostly Technics turntables which are very common over here in my city, but after realizing the price for a second hand Technics SL-1200MK2 I wanted to give a try to restore this very old one that I have since 20 years ago. I thought I would prefer to spend the money restoring this one that to buy one.
The entire tone arm assembly was missing (I used in another turntable 20 years ago when I was DJ), also foots were, and the worse... not spinning.
So far I have spent some days buying things and also was checking all the circuit with help of the manual. Bought a second hand AN6675 drive IC that turn out to be shorted (it seems I am not learning from experiences and some of you which already told me not to do that on that known site), whether because it arrived like this (shorted) or because I did the mistake and put a wrong transistor as rectifier... any way I learned a lot, and now I am waiting for a new AN6675 (from 1200.com). I hope this solves the not spinning problem, if not, has to be the AN6680. I already check some voltages and every thing seams fine with the AN6680 (I don't have an oscilloscope, so I only check voltages). The other little transistors around seams ok.
So far these are the things I have bought:
1. A complete tone arm assembly (second hand with the arm bent). Apart from the arm bent, is in a good condition, and bearings are ok
2. Arm tube.
3. Tone arm balance
4. A new start stop button
5. New AN6675
6. A set of feet
I don't have a dust cover, but I have no plans to buy one. My idea is to create a wood base and in the way also some kind of cover too.
After I have this table working I will change all the electrolytic capacitors. Also have heard of an external Power supply mod, but it seems the only noise thing in the power supply is the Transformer, so I have plans to leave it outside and build an external wood box for it. (what do you think about these guys?). I am also thinking if I try to find the original color to paint it (Something that will be difficult here specially because I am limited to spray paint), or to paint it in black.
This turntable was given to me for parts from my brother 20 years ago, before that the turntable was in a radio station, it suffered a lot there. I am a little afraid, because I am putting too much work and money in this, when with may be the same money I was able to buy one in a very good condition, but I like to restore things instead of put them in the garbage...
Well guys thank you for the reading and for the future company in this new project.
Cheers,
Rodolfo
These are some pics before disassembly (today wile I wait for the AN6675 to arrive (I order to be shipped to my sisters house in The States, and then she sends it to me to Colombia, as everything I need, so this is mainly a waiting game
And this is the second hand tonearm I got:
More pics of the disassembly in the next post...
Yes, I so that kind of finishing and I thought it possible for my TT, but at the end I choose to remain loyal to the original painting. I already have the stencils, but I think I kind of like it without them. I will add the sumiko pearl to my list, but first I have an Ortofon OM (a gift from my dear friend @Bratwurst7s ) needing a stylus... but still not sure -or not able- to spend $534 USD (LP Gear price) on the OM40 stylus (My ambition always wanting the best :S). Not only that, but I also have a possible Denon MC DL-301 (Not sure if it's the right reference) to retip, BTW, I am receiving advice whether this repair worth the money it could cost.Have seen where people sanded the paint of the aluminum wet sanded the aluminum with 600 grit and bugged out to a polished finish and bought new control stencils looked really cool they also make covers of different collars or chrome finish that goes on the turn table lots of cool stuff for those ! I have the pl120 Chinese knock off of that table ! While not as durable it performs pretty decent ! Have a sumiko pearl cartridge I put on a definite inprovement ! Over the stock cartridge ,
Rodolfo,
Beautiful repair/restoration of this classic workhorse. You did superb work, and got it running. I love this thread. AK at it's very finest.
Excellent detailed work @morfeora, you should be proud of yourself. Thanks for sharing it with us.
