Harolda
Well-Known Member
Hi john, I was also referring to the version of the f-2772 board you have in your amp, just like Ron.
I removed the ceramic capacitors on the track side of the f-2270/1 MM boards, per advise from Martin Kuehne.
It seems however that you have a later version, because you already have 47pf black flags for c15 and c16 on the f-2775 board. The earlier models have 33pf here (that is what I had) and I read that someone increased them to around 133pf.
I am really interested in the details of your flat amp pcb, components and grounding sheme as soon as you are working on it. Succes.
