If anything changing the caps will give you a more detailed bass, without increasing the bass. The loudness switch is designed for the exact conditions you are using it for. There is a curve that describes how you hearing perceives frequencies at certain volumes. These are known as Fletcher-Munson curves. Here's some light reading. https://www.google.com/url?url=https://en.wikipedia.org/wiki/Fletcher%E2%80%93Munson_curves&rct=j&frm=1&q=&esrc=s&sa=U&ved=0ahUKEwis5t282_jMAhVo04MKHbAeAjsQFggUMAA&usg=AFQjCNGlm2IhF7vN8EiFAY0fq3VenUv_aA
Basically at low volumes bass and treble appear to be attenuated more than mid range frequencies. So the bass and treble frequencies get boosted either by application of the Bass and treble controls, or the loudnes control or for the more extreme guys, Both. As volume increases, Bass and treble boost is attenuated down to normal levels, with the loudness eventudally being non functional somewhere near 1/2 volume (by knob position).
Well then I will definitely change the caps. More detail would be greatly appreciated.
BTW I traced the source of the loud buzz to the interconnect from the tuner to the amp. I was really sweating that! Those old cables need to be replaced or at least fitted with new RCA plugs. Also I have never come across any threads were someone has replace the RCA inputs. I won't do it on this restoration but am definitely thinking of doing it to my x-202b. Those old RCA inputs are really crap even if they are re tensioned.
