alexhastings
Cool - I ordered those, so it was an easy replacement!
First checked the DC output voltages to make sure we weren't just triggering Q3 or Q4, but both appeared to be pretty close to 0V (mV level fluctuations on the DMM - probably the actual signal?)
Replaced Q2 with the 2690AYSTU, and initially, it stayed in protection mode when I turned it back on. I started probing the Q2 voltages to see what was going on, and the instant I hit the collector pin (which looks like it goes straight to the relay...), it clicked on. Appears to be working fine now - I tried cycling the power a couple more times, and the relay kicked on on it's own. Any guesses on why it didn't kick on without the probe the first time?
Q2c has been +50VDC each time I've checked it... in and out of protection mode. Amp worked for about 15 minutes after the relay initially kicked on, when went back into protection mode.
. Reflow the solder on Q2 and the relay coil.
