ehc68
My SX-1050
markthefixer said:I reviewed the thread and any PM's and we didn't do anything about replacing Q9 and Q11, correct?
No we didn't because I pulled them out and tested them and they seemed to be ok.
Q9 - Voltage on base and emitter was 680mv.
Voltage on base and collector was 680mv.
Nothing when reversing polarity on these.
Nothing on collector and emitter.
Q11 - Voltage on base and emitter was 598mv.
Voltage on base and collector was 598mv.
I will go ahead and start pulling and testing the transistors right now. I may have an answer in a couple of hours or so.
Don't sweat the mishap on the lead arrangements. I'm sure it's a lot easier to leave out details like that when trying to explain it than to actually be doing the work yourself. Checking details like that when you've done it so many times becomes second nature when doing the work yourself....so I completely understand.
I just ASSumed that on a cross reference that the lead arrangements would be the same. That's what I get for ASSuming!!:nono: :tears:
power OFF !!! , if you did it with the power on, not only is the reading wrong, but you could have damaged the meter.
