In later models on the power supply, those 1 Ohm fusible resistors were replaced with 1.5A pigtail fuses for the pair, and 1A for the other. They were soldered in vertically covered in a clear plastic tubing. I wired in remote fuse holders utilizing 3 existing screws mounting the transformer, but of course longer screws to make up for the thickness of the fuse holders. If they did blow, no more surgery needed to replace them. A "one and done" for them. A factory service bulletin and "kit" supplied the fuses, tubing, and stickers for on the board. If you use 1 Ohm resistors there, they should be 1/4 watt so they blow if need be. That's why they were "fusible" to begin with. To protect the transformer.
Looks great! As long as the driver board doesn't pick up any AC noise, that will work just dandy.I decided to work with what I had and to follow Sansui's use of fuses over fusistors. Thanks for the heads up. I made my own fuse holder from protoboard and mounted it to the driver amp bracket. It is easily unbolted from the bracket should the need arise. There is plenty of clearance to the bracket and the driver board and the fuses are still accessible. I’m pretty happy with the result. On reflection, I should have run the wires to the left of the fuse board but it will do for now.
What do you think @Skywatcher ?
View attachment 2582956 View attachment 2582957 View attachment 2582958 View attachment 2582959 View attachment 2582960 View attachment 2582961 View attachment 2582962
No noise whatsoeverLooks great! As long as the driver board doesn't pick up any AC noise, that will work just dandy.
Is that AU555a to the left of the 8080?This was my first Sansui Dolby receiver restoration. I am forever grateful for all the others who have shared their experiences with the 8080DB (and 9090DB). I have tried to leverage the best of what I could find on AK, given timescales and budget and hope I have done this unit justice. Note, the case is a work in progress.
I am truly blown away with the SQ through every input but especially Dolby FM. This is why I am a Sansui tragic!
View attachment 2583699 View attachment 2583700 View attachment 2583701 View attachment 2583702
Yes. It is number 39 and now sold. I have number 40 on the bench. My restorations are based on @Leestereo but with all new components of every kind including all resistors. Amazing sounding units. Can't believe I've done so many!!Is that AU555a to the left of the 8080?
Your mods are legendary Ben! I've also done a few of your 717 designs. Absolutely love your work.@BradWil: Was the 555A the most popular amplifier in Australia? Forty restored and upgraded 555As, that is impressive! Now where did I put that patent application...
I don't unfortunately, however if you visit https://tolisdiy.com/2019/02/23/san...rrection-creating-a-modern-f2624-replacement/ you can get all the info on the legendary ToliToms F-2624 PCBI'm going to have to make an order for all these parts i wonder if you have like a digikey cart
Novice question for you: In the past I've replaced caps on computer MB's and on my engine lathe, and every source at the time told me to always match the original uF, but I can increase voltage to anything so long as the form factor of the the new capacitor doesn't become an issue. So why didn't you follow this "rule" repairing this receiver?Filter Caps
The original 12,000uF/63V NCC items were replaced with 15,000uF/63V Nichicon LKG series, with a matching 40mm diameter.
