Hi Tom,
Did you use a small veneer router for the edge trimming, or one of those
ceramic blade knife trimmers?....Veneer looks spectacular, should really
pop in the finishing step!........Thanks, T:thmbsp:
For what it's worth a 4x8 sheet of 1/2" walnut plywood with a MDF core is $124.32 plus a $15 per order freight charge. I had no idea it would be that expensive. You can buy a lot of veneer for that money.
- Pete
Hi T,It is time to file the edges, I use a knife to get close. Most of it was routered, but the front beveled edge has tombe done by hand, then filed then sanded with an airpowered sanded, this is what gives the very smooth and flat finish, hard to get this flat by hand. The case has been test fitted and now is ready for stain, I have a stain that matches the original Sansui very close.I have a stain that I like better it is a cherry stain when you put it over walnut to looks fantastic but it is not colse to the original ,which would you use.
I left the lacquer the stock color.I do not use wax but you could, also wax will smuge and leave fingerprints so I do not use it on new wood . stay tuned for the finished case as it will look different than it does now.Hi Tom,
Well, looking great, did you 'redden' the stain, it appears a nicer tonality
than the standard?...When you finish the lacquer work, sanding, do you
apply a wax, or is that finished at that point? Hope you will post the
completed case on the receiver, and give an idea on pricing, Looks great,
Thanks, T:thmbsp:
Looking good. Lacquer is a great finish. I like it much better than any kind of poly. The trick with the nails to hold the work up is a great idea too. Do you pre drill holes for them?
- Pete
Your case looks fantastic! What type of adhesive are you using to attach the veneer to the plywood? What type of precautions, if any, do you have to take to prevent the finish from attacking the adhesive? Or is this taken care of by the paper backed veneer that you are using? You do great work and this may be the inspiration I need to tackle the case of my Sansui 7000 receiver.
Thanks for sharing this with us.
