First a comment. DC can be check most easily at the emitter resistors - the large white blocks associated with each output resistor. Unless one is open, they will all be at the DC offset, or within 30 mV of the DC offset.
Best to use clipleads to measure. The ends of the resistors marked Lch and Rch are the output voltages. (should be near zero - if no0t go back to amp and trouble shoot) . Next check the 33 volts. If below 25, could be bad capacitor C603 (usually buzzing from relay or intermittent not pulling in). The rly+ should be 33 volts if the relay is not trying to energize , and should be 24 when energized. The rlly- will be 33 (same as rly+ if the relay is not energized. It should be less than a volt when relay energized. rlu+ and rly - can be measured off the diode d613.
The "V" where a couple of resistors and diodes come together is the (for lack of a better description) I call the trigger voltage. It should be around 1.8 volts. If there is a malfunction, it will be lower. If it is 1.8 (or higher, then the relay should be on. If not trouble shoot diodes d612 and transistor tr603. The collector of 603 is same as rly-. The emitter is ground.
V th is the voltage from the thermistor, which is mounted on the heat sink and connected on the back side of the board (You can see it on the third picture of post 8 in this thread - lower right of the red 2 dot.) . It has to be higher than 15 volts, or the "V" will be pulled down.
The funny reddish brown blobs are dual diodes. They can also cause problems.
Start with the L and R ch voltages, then the 33 volts, before going after the rest of the protection circuit. Hope this helps.
