SebastianH
Member
Is the AKL a plug in or how you get it in your library?
Yep, that is at least the easiest way to install it. Plugin and Content Manager -> Libraries -> Alternate Kicad Library. Then you'll find both the standard and the double libraries (for THT components only) in your footprint dialog.
Any reason you didn’t go for 4 layers PCB for dedicated ground planes ?
Importantly it's cheaper and I already have twice as many layers as Sansui used
I think this isn't always quite as trivial as just adding a ground plane. But maybe it is in this case. If you (or someone else here) has experience with this, I'm always happy to learn... Would be a cool experiment for sure.
