And offered no proof?the guy that sold it to me said it was fully recapped and serviced....
Took his words for it…And offered no proof?
How much would someone pay for a untouched 919 nowadays? What would you pay?Without knowing what you paid, it's possible that you did OK, because an unmolested original is still a worthy amp to obtain - but not to use in its original state. Make no mistake, it needs to be completely, knowledgeably refurbished with new caps and such. Now you have an idea of what that will cost. Finding someone to do the job is not a trivial task. Be careful to find a good tech.
I paid… 1300.I'll stick my neck out and say "for repair" or unrestored AU-919 on ebay (with the three the search called up recently) looks maybe about US$750 US - $1,000. Let's see what other AK's think!
I just saw the thread … incredible work. Wish you were located in NYC…Yes, their failure can lead to the amplifier becoming unstable, when that happens other components such as output transistors can be damaged or destroyed, and original replacements are extremely hard to come by.
Just to give you an idea of what's involved, I happen to be reconditioning an example of the Japanese Domestic model of the AU-919, called the AU-D907 right now and illustrating the process here on AK, there are several older threads illustrating the same process,
https://audiokarma.org/forums/index.php?threads/au-d907-for-restoration.980756/
Update: @sjackh
Here is a link to the thread which is now regarded (by me at least), as the 'Gold Standard' for AU-919 restores by AK member Leestereo.
https://audiokarma.org/forums/index...ration-and-upgrade-of-a-sansui-au-919.698011/
Ouch. That may not be way too high to pay in the current market for an unmolested, fully working original unit, but I think it on the order of 3 bills too much. Irrespective of that, I'd say there is a solid case to be made that the unit was misrepresented at sale (even if fully working) if it was specifically presented as a recapped/restored unit, which it obviously is not.
I don't know the terms of the sale, or how long ago it was consummated, but if there is any warranty or return period on it, I'd probably try to get the refund just on the principal that the seller blew smoke up my ass.
Now, if the seller is willing to "make it right" and adjust the price by refunding a few hundred bucks, it may be worth keeping and having a proper restoration job done. Still would leave me with a sour taste just from being lied to. The only way the seller - maybe - gets a pass from me is if he flipped it after buying it from someone else without ever verifying the work was done.
The remaining problem right now is that if you keep the amp, it is not advisable to use it in its present state. Yes, it works. That could change at any moment if a black flag is just far enough off value that is lets loose and blows one - or both - channels. OE output devices are nearly impossible to find, and even if using the more readily available suitable TO-3P replacements, is an expensive repair job.
So, you can commit the money to have it restored now so it's safe to use, mothballl it until you are willing or able to make the outlay for a restoration, or try to get the seller to either sweeten the deal or give you a full refund and return the amp.
I think you have acquired a good unit to restore properly and for that I think you haven't spent bad money at all.You are starting from a good, working unit, so you do have that to be thankful for at the very least.
Starting with a clean, undamaged unit is a huge plus when doing a resto.
This what's matters...I was just too naive and excited to finally get my hands on one
From looking at the attached images, you can see the glue???What you paid IMO isn't too bad a price considering it looks unmolested. Of course the elephant in the room is the infamous 'Sansui Glue' which if the OP does a search will find this is another issue that can be corrected with a proper restore. The glue is used on the printed circuit boards to immobilise large components but unfortunately over time goes corrosive, and in bad cases eats through component leads. Just like the 'rust that never sleeps' that glue will continue doing its worst until it is removed in the approved manner.
Not in your pictures, but it is a virtual certainty that your unit has some under some of the larger components.you can see the glue???
Ok Does the amp work? Sorry i did not read the whole thread. I live in Brooklyn Sheepshead Bay Area and could restore your amp. However i won't be able to do it earlier than March or most likely April as i have some personal issues.
So if you do not find anybody before that I could help you.
