sansui au 919
georgedannyg
Well-Known Member
last week i bought the sansui au 919 off of ebay said it blose one fuse it shoud be in this week i will post pics when it comes in
well i got my sansui au 919 in and the guy said it would blow one fuse so i done some checking and found two out puts on the right channel blown and on the left channel found one drive transistor shorted base to collector but the out puts in the left channel where fine the right channel i had some 2sa909s laying around and a 2sc1586 laying around so i put them in to see what else was going on so i brought it up on the varyac and the relay kick in the left channel plays fine the right channel has low output and distorted i even tryed to use it as a power amp and the right channel is still distorted and the drive transistor get hot so im going to order parts and recapp both driver boards and replace the transistor on the driver boards on both channels and hopfully the new transistors fix the distortion on the right channel
Replace all the 'black flag' pf-value capacitors on the driver board with silver mica caps. And if one channel blew, look for burnt resistors, including emitter resistors (mounted on the TO-3 transistor sockets on the heatsink assemblies).
thank echo wars i check all the resistor they are fine i check the emmiter resisitors they are fine the heat sink of this amp looks like a g 9000 heat sink did they take some of the dezine off of a sansui g 9000
I think that's one of the longest sentences with no periods/punctuation I've ever read! :D
You forgot to mention the total lack of capital letters and the horrendous spelling.
Sorry, George, I don't mean any harm. But Good Lord, Man!
Hope you get that 919 right.
Dave
well sorry you all dont like my spelling or periods guess i will have to get spell check or i just wont put anymore threads out or didi i not spell that right:D
Man if you're out there fixing AU-919's it don't matter which way you're spelling and punctuating it:thmbsp:
- Neil
Nice to see an AU-919 being bought back to life. Hope you get the remaining problems resolved with the recap!
I took the liberty of cleaning up the punctuation and spelling, and editing it a little to be a bit more readable. [I don't mean this as a criticism; perhaps you have valid reasons for writing that way, but text with no punctuation is difficult to read and can be confusing and misleading. Just trying to help ease communication here.]
Maybe this is more easily readable (?):
Well, I got my Sansui AU-919 in, and the guy said it would blow one fuse, so I did some checking. I found two outputs on the right channel were blown. I had some 2sa909s and a 2sc1586 laying around, so I put them in to see what else was going on.
On the left channel, I found one drive transistor shorted base-to-collector, but the outputs were fine. I brought it up on the variac and the relay kicked in. The left channel plays fine; the right channel has low output and distortion.
I even tried to use it as a power amp. The right channel was still distorted and the drive transistor got hot, so I'm going to order parts and recap both driver boards and replace the driver-board transistors on both channels. Hopefully the new transistors will fix the distortion on the right channel.
That maybe easier for readers to follow, I hope. The content --what you are doing-- is great!
C'mon guys!
Anyone ever heard of e.e. cummings - one of the greatest American poets ever - used to write just like that so's he'd get his message across more clearly without capitals and grammar and even spelling.
georgedannyg is one of a handful of guys on this entire forum who would DARE to tackle a 919 with any confidence of success. We need more guys like him and you scare him off by criticizing his grammar :nono:
Come back George! I for one want to hear how that big 919's doing now.
- Neil
Im not mad buy any means when i get in to typing and dont think about putting periods or commas or capital letters.But one the sansui au 919 im in the process of replacing all the transistors on the right driver board. And replacing all the caps on the driver board.And doing echwars mod on the power supply so i will report back i cant wait to get it up and runing to see what it sounds like. And sorry if there is to many and,the,lol just kidding:thmbsp:
Well guys the sansui au 919is alive. I completly rebuilt the driver board on the left side i was having trouble with.And dailed in the dc and bias current to specs and done echowars mod on the power supply when i get it reapped i will post pics thanks guy for all your help and thanks for the mod echowars.:music::thmbsp::banana::D:smoke:
Searched around a bit but couldn't find any info on the EW AU-919 power supply mod.
Can you give more details?
- Neil
Hey George, I can not type well either. it takes to long. This is a forum for audiophiles, not english class....
sometimes people forget where they are at.
Regards, Mike
From the horse's mouth! Thanks for that EW.
It's a beautiful mod - turns spaghetti into a clear road-map.
- Neil.
:thmbsp:And it is well worth it trust me your not fighting with the wires and you dont have to worry about sodering them back on thank echowars
here is the new baby shineing like a new dime.And the new caps are braking in nicly this one way a mess.the only thing im missing is the cover panel in the back that hides all the wirers under the top cover
i did not replace the main filter caps u replaced the power supply caps on both power supply boards and replaced the caps on the driver board with post pics when i get off work of the inside
