Leestereo
The back to back restorations of a Sansui AU-9500 and a AU-717 last year provided an opportunity to sonically compare them against each other. With a source component connected through the line stage, the amplifiers were very similar sounding, making identification of which amplifier was playing at any given time difficult. However, when the source was a turntable, the amplifiers were easily identified: the AU-9500 had a "warmer" sound characteristic, and with source material with low bass content (<50Hz), that range also that sounded more prominent.
With another AU-9500 restoration project on the bench, a further examination of this subjective sonic difference seemed appropriate. An analysis of the RIAA equalization of the AU-9500 phono stage revealed that there was a significant deviation in the bass range (due to an error at the 3180µs correction).
As can be seen in the graph above, with the stock AU-9500 phono stage, there is a rising bass response beginning at ~160Hz which reaches +3.4dB at 20Hz.
In contrast, the analysis of the AU-717 phono stage did not exhibit any such gross error, the frequency response was excellent; within a 0.3dB window from 20Hz to 20kHz (note the use of a higher resolution vertical scale):
