Note: lengthy post follows.
I find it difficult to believe these were bonafide design errors. Not that the engineering staff at Sansui were infallible, but even without the aid of computer design and perhaps a slightly different understanding of the math involved then versus now (as with speaker design predating development and widespread adoption of Thiel-Small parameters) I somehow think these were intentional design decisions. Likely not ideal ones as we consider them from a contemporary point of view, admittedly.
Are there any known running changes to the RIAA EQ circuit in the AU-9500? It is the most glaringly unusual EQ curve of the bunch in that era. Enough so that it almost looks like a possible design error. If there were changes, that would support the idea that the original circuit was either done incorrectly, or that later units were at least changed in response to customer feedback over it "not sounding right". In searching about, I find no indication that running changes were made, FWIW.
In either above case, I expect a TSB would have been issued to document any such changes. I've never seen one, nor do I have any knowledge of whether there are or aren't, just throwing out ideas here. Obviously the phono EQ on the 9500 and it's smaller sibling models can be pretty easily modified for a more uniformly flat response curve as already demonstrated upthread.
Then too, is it certain the RIAA spec has never changed at all since it was first established? Not being a hardcore vinyl guy, I've never done a deep dive into the minutia of that. I know early on (1950's) there were competing phono EQ curves, have even seen at least one old Sansui tube era preamp with multiple labeled settings on a rotary switch for different curves that apparently were still in use. Clearly RIAA prevailed in that regard, essentially becoming an international standard as all the others look to have been abandoned.
I also wonder if these were intentional design choices since some of the early solid state integrated amps have overall frequency response curves that are clearly far from flat, from say 20Hz to 20kHz. There was a thread some time back here where this was discussed regarding (I think) the AU-505, or perhaps it was the 101. If not mistaken, I think
@kevzep posted a graph in that thread of the frequency response profile, and it was no where near flat. Such a design now would be frowned upon by those desiring the 'wire with gain' discipline, but in the context of the time, may have been thought perfectly normal.
There appears to be some precedent for Sansui intentionally designing circuits that tend to favor an enhanced low to mid-bass response. We know this is a fairly well noted but subtle characteristic of the cap coupled era amp designs, and is part of what gives them their unique sound. It may not be accurate, but it is musical.
Might this have been done to compensate for typical deficiencies in the common speakers systems of the day? Or just an arbitrary decision made because those in charge of design and testing simply perceived it as sounding better at the time of product development?
It wasn't until the debut of the AU-919 that the company design philosophy clearly shifted to a more purist approach of endeavoring not to color the sound of the source signal from input to output. Subsequent topologies and designs by Sansui explicitly pursued this objective, culminating with the Alpha and it's slight sub variants. This was a mindset that took hold among most of the Japanese majors around that same time frame, though one might well argue Yamaha had already be striving for that previously with the "natural sound" designation on their product line.
