Kale
Those 2SC2071 and 2SA939 I have found in one G901DB as predriver transistors, but in my G8000 as predriver transistors Sansui installed 2SA818/2SC1628 which are very rare, and they are rated as 150V, so I think that 160V for B649/D669 is quite enough. And one very important data is fT for B649/D669 is 140MHz!!The 2SC2071 and 2SA939 are rated at 250V, and the B649 and D669 at only 160V. If you do not NEED the high voltage capability, I'd use the 160V-rated Sanyo 2SA1209 and 2SC2911, or going up in voltage, the 200V Sanyo 2SA1380 and 2SC3502. If you really need a rating of 250V or more, then the Sanyo 2SA1353 and 2SC3417 would do well.
Why all the Sanyo's? Seems high-voltage, wide-bandwidth TO-126 transistors are getting tough to find, and Sanyo just happens to have a lot of good ones.
But what is strange about B649/D669; Ic is 1.5A and in peak Ic can be 3A!! I am not sure that is true data from datasheet, or yes :scratch2:
Regards!
