Hi Sansui experts! Wondering can anyone recommend a drop in replacement power supply filter capacitors for a Sansui BA-2000 power amplifier? Originals are 12,000uf 63v thanks !
Again - don't do screw terminal. They 90% won't fit and are much more expensive.Thanks for the replies guys the dimensions are 50mm x 75mm I was hoping to find a version that was screw terminal that fits the original metal brackets they hold onto are there none left available??
It looks like those have been re-stuffed - note the wires emerging from the drilled out rivets.Here’s a photo I found online of the brackets I’m referring to I haven’t pulled mine out yet as I’m working on the other boards first and want to collate all the parts into one order
Yup height. Plus no matter how you cut it, modification is needed. The old screw bracket bus bars are the wrong spacing and wrong hole size....honestly much easier to just wire it without the old bars.I'm curious - why won't a screw terminal cap fit - is a question of height? (Remembering that the OP's original question was for a "drop in fit" and a snap terminal cap would require some modification to the connections ??)
