Replaced trimmers on R channel driver board.
Was not able to make much change on main amp current on that channel, about 3 mA. May be an issue there. Turning VR803 didn't do much.
Then adjusted VR801, 802, 804. Was able to get 0.5 V across R804 pretty easily. DC offset adjusted to about -52mV and VR804 to about 1mV. Could not do much better than that. Sames as on L channel, if I adjusted VR804 up, I could get lower DC offset, so this was a balance.
Listened through headphones. Have both channels stereo. Will try some throwaway speakers next.
If that is ok, go through the same procedure on full line voltage?
