Thanks Morden2004 for manual.
A couple questions for you guys:
I was able to get the DC down to 0mV, but they're not stable. Is it normal for the numbers to jump around? It's something like 00.13, 01.02, -00.78, 12.31, 01.87, -01.54, -00.21, 01.09, 06.51, 01.39, -00.43, etc. I waited about 15 minutes before testing.
Also, I tried measuring the Bais, but all I get is nothing, 00.00, -00.00, 00.00 on both channel. I tried cleaning the test points with a q-tip and some DeoxIT, but nothing. What could I be doing wrong? The volume is at minimum. Speaker A is turn on. Power is on of course. DMM is set to auto on mA. Basically, you measure bais the same way as DC, except that you use the testpoints instead of the speaker outputs, right???
Thanks,
Tom
