Why are you using two?I am happy to report Saga + on the left channel and Saga + on the right channel, is hella fine way to listen to some Schiit.
Well, from what I gathered from headfi.org the upgrade may have changed the balance of the BF2…. so “ better” may be jumping the gun. And maybe leaning towards a leaner sound.Too funny. I guess with the different sides, and the wide variety of 6SN7 tubes, the Freya+ can be tweaked to sound any way a user wants. One day I'll upgrade my Saga to a Freya. But, the Saga still sounds awesome. Especially after I upgraded the capacitors.
I'm also planning to upgrade my Gungnir to Multibit. Though, with the chip shortages Schiit is experiencing, I'm not sure how soon that'll happen? Plus, some are saying the new Bifrost 2/64 now sounds better than the Gungnir! What to do?
Sure.My Bifrost OG (original generation) MB DAC does exhibit limited deep bass, and it definitely has a slightly boomy mid-bass. Forward in the upper mids as well. But, like all Schiit MB DAC's, the longer it's left powered on, the smoother it becomes and the better it sounds.
In comparison, my Gungnir D/S DAC has tremendous bass, tighter and much deeper. Great bass slam and dynamics too. Using the Gungnir, seems as if a subwoofer has been turned on in the system. Now, hopefully for X-Mas, I'll get it upgraded to MB, so I can experience the same 3D dimensionality of the Bifrost MB.
Minutemen - This Ain't No Picnic - YouTube
Drove up from Pedro.........(Broham)...
The Man In The Van With A Bass In His Hand....
Too bad, Gumby was a great DAC - glad I moved on before it obsolesced thoughI’ve had the Bifrost 2/64 for about 2 weeks now. I came from the gungnir multibit, and I’ve also had the old Bifrost multibit and the modius.
I can tell you that Mike Moffat (Schiit dac engineer) still has the good stuff. Detail, dynamics and imaging all on par or even better than the Gumby. Gumby SNR is 115 db, while the 2/64 comes in at 124 db. Now I know that specs don’t tell you the whole story, but still.
Every generation, they seem to find solutions and improvements. BTW, they are saying that the Gumby’s days are numbered due to parts/chips no longer in production.
Umm, back to the original subject -
I currently have a Freya+ and an Yggdrasil Analog 2 DAC in my main system. Freya+ is running Tung-Sol 6SN7GTB tubes (although I find them a bit microphonic, but only noticeable when operating the volume control.) Power amp is currently a Purifi 1ET400A connected via balanced outputs on the Freya+ and my primary input source is a Pi2AES/Raspberry Pi streamer with Roon. Using all balanced inputs and outputs, the system is perfectly silent.
Very happy with both Schiit components. Had a Bifrost for many years and upgraded it to the multibit, before selling it off and going with the Yggdrasil. I've never had a quality control issue - everything has just worked as it should.
What cable are you using to connect the Raspberry Pi to the DAC?
So we are pretty much listening to the music, like the good ‘ol days… not analyzing your equipment.
And just to add that’s one thing I would like to see.
Is for example some one going from a Schiit BF2 OG, to A Yiggster OG.. what type of changes they made system wise to optimize the change.
Seem the headphone guys are more likely to make changes for obvious reasons… but if you have the right information from them on why and what changes they made.. you should be able to apply some of it towards a speaker driven system.
