Ok... I finally got my Schiit Magni 2 in the mail today. It's been just about a week since I ordered it and with the time I would have expected for them to fill the order and then get it sent out, supply chain issues, USPS issues, etc I thought that it may have taken longer.
Anyway, I hooked the thing up and made sure that the settings conformed to what I read online for the specs for my Denon DL110 high output MC cartridge. I wanted to try this thing because of the extra settings that it has over other phono preamps (at least ones affordable to me) since I felt like my old Cambridge 651P preamp wasn't quite working with this cartridge, which came on a new (to me) Yamaha PF800 turntable. The sound I was getting was very good, but I was a bit disappointed that the gain was so low and that I had to turn my amp up so much to get the same volume as I got with my old table, not to mention from other sources. I put on a bit of two albums: Yes - Close to the Edge and John Abercrombie (with Jack DeJonette and Dave Holland) - Gateway (both records that are great for testing audio IMHO) with the old and then the new preamp to compare, noting the db levels I was getting with the old so I could indeed see how much louder the new one is. With the gain on the Schiit set at 48db, which in my research seemed to be the consensus for this cartridge, the volume was dramatically louder... like maybe 8 or so db. What I realized though, which is probably obvious to many if not most of you, is that beyond a certain volume, the sound starts to get compressed and ugly so that the extra gain going into the amp doesn't mean so much as one needs to turn the amp down a bit anyway for everything to sound really nice. That being said though I still think that I may have gained something in that department as I do think that everything sounds better a few db louder (with the volume know turned up less far) than before, it just isn't fully the 8 db better than the actual difference in loudness between the two preamps (if that makes sense, it's a difficult point to get across).
Other than the loudness thing, I have to admit I don't hear big differences. For me, unless I can do a back and fourth A/B test, I kind of have difficulty comparing things, at least if they're fairly close. I feel like maybe the old Cambridge is more open and airy on the top end (which I like!), but the Schiit has a bit more presence with vocals (midrange) and with the upper end of the bass. On the Close to the Edge album, I missed some of the spaciousness that the Cambridge had, but Jon Anderson's voice seemed to be more present and Chris Squire's bass seemed to have more of that clanky upper end that he's known for. Kind of a tossup between the two and knowing that I might not have bothered upgrading to the Schiit, but then again as cheap as that thing is it seemed worth the gamble, and even if it isn't quite blowing my mind, it does sound very good.
I have to wonder if this kind of thing is something that's considered to need a break in period? If that's the case, then it may be that this thing isn't yet showing me what it can do and after some hours of use it could sound far better than the old preamp...
I somehow feel the need to say that with this preamp, I now have 3 pieces of Schiit in my system! I have the Modius DAC, the Vali headphone amp and now this thing... all in the sparkly brushed aluminum version (by far my favorite over black). My only complaint, and it's admittedly a very small one, is that the three pieces aren't really well proportioned to go together. The Vali and the Magni are very small but still too large to both be set across the top of the much larger Modius.
