Schiit Fans ?
:rflmao:im still tryna see that from 8-10' away.
Yep, you have to make your own mark on the knob so that your not guessing how loud you have it cranked up !
For XLR inputs my volume knob usually sits at the 11 O'clock position for my preferred listening level.
For RCA connections I need to set it up a bit higher to the 12 O'clock position to get in my comfy zone.
zackely!
ive not tried xlr, yet. the difference is most likely too small for the effort. maybe ill give it a go one day.
It is well worth the effort/price to use the two XLR inputs on the Freya if you have any equipment with XLR outputs. Also use the Freya's XLR output to your power amp if you can... way quieter this way with an absolute dead black background.
:music: It is well worth the effort/price to use the two XLR inputs on the Freya if you have any equipment with XLR outputs. Also use the Freya's XLR output to your power amp if you can... way quieter this way with an absolute dead black background.
Ditto and more critically - I run a semi-concealed 2 channel balanced Mogami “stereo” mic cable around the room ending with an ART CleanboxPro and my headphone amp next to my same listening chair as for speakers. As Schiit recommends run the headphone amp at full volume and use the Freya to control the volume. With the SS Fosi amp my LCD’s are inky black as loud as I dare go. Not so much with the venerable Lyr (v1) in that setup so it’s bedside with a Bifrost Uber we’re all happy as clams.
Nice talkin’ Schiit with you km
The only other equipment that I have with balanced outputs is my Topping E50 II and the distance between that and my Freya is short, maybe two feet of cable length.
The Topping also has TRS jacks as opposed to XLR. Any kind of compromise or compatibility issue there?
Considering that I don't have any issue with noise in my system, can I really expect to hear a difference if I tried that balanced connections? I thought that main application was long cable runs.
Some/most home audio XLRs will take TRS but not vice versa
You could try it and listen to see if there is a difference for you
The XLR play about 6db louder than RCA connections.
I lost/forgot my 4-digit Forkbeard security code so can't access the stack on my phone app. Anyone know how to reset it? (SchiitTalker was no help.)
whelp, you are right. it does make quite a difference. though it's not the cabling itself.
bought these really nice xlr cables from fosi audio. they are excellently made. nice heft. great feel. the connectors are dope and fit like a glove. they also have a satin finish you can feel.
these are prolly the nicest cables i own.
the difference in sound is due to using the balanced circuitry in both units, particularly the freya being given a cleaner signal, goggle says.
immediately, i noticed the extra 6db of gain. it plays out as more dynamic. there is more detail (particularly in the mids and upper bass), the highs are clean and clear. much more detail. soundstage improvement.
and black. my system was already dead quiet. yet, it is even quieter somehow.
sposedly, the balanced circuitry lowers tube noise 20db. i didn't notice it before. but it's just, quieter than it already was.
thank you, sir. :thumbsup:
Glad you like it! Balanced is the way to go with Schiit equipment. I use XLR cables on everything that has the capability: In my office system I have my Parasound T3 tuner hooked to the Freya with XLR, my Mimir DAC also connected using XLR, the Freya's output is sent to the Lokius EQ via XLR, and Lokius output to Wotan amp is XLR also. The system is Egyptian mummy dead silent.
Ok, I found the solution. Factory reset FB settings by power cycling while holding a button. In my case - Mimir - turn the unit off, then power it back up with the Input select button pushed in for a few seconds. All four lights blink, then release the button.
Reset didn't work first try, so I unplugged the wall-wart for a minute or so. Not sure if that is a requirement or just a coincidence.
I've got a pair of balanced cables to go between my Freya + and my Topping E50 II on order. I'm curious to give them a try.
in my paltry experience, definitely worth the try. im glad i did. thanks to @krautmaster's suggestion.
Hopefully your amp is balanced too. If I upgrade to a dac that's balanced, Mimir or Bifrost 3, then I'll go fully balanced as well.
My entire signal path is balanced, from my dac and phono pre (unfortunately, not my cartridge) to my preamp, dsp and amps. Any noise I might experience isn’t coming from my cables or amps.
No can do.
I'm bi-amping two Adcom GFA555 II's which are not balanced. I also have a DSP-408 between the preamp and main amps and that isn't balanced either.
Nothing is written stone so maybe one day I'll wind up with a fully balanced chain.
