Sorry for the delayed response, had a pretty busy weekend. I've been using the assembly manual and the service bulletin to try to determine if it has already been done on my unit. I checked out the assembly manual part 2 and I'm still not seeing the can sections being individually numbered. I see some numbers but it doesn't make sense to me the way they've numbered the tabs. They appear random at first but when comparing to the assembly manual it looks like the numbers I'm seeing refer to how many connections should be on each tab before soldering the connection. When comparing my amp to the service bulletin and the assembly manual steps that are replaced with the service bulletin update it looks like it has been partially update. Most likely this unit was made after they swapped the can caps from a 30/30 to a 20/20/20/20 but before they came up with the rest of the update. So I have the correct size cap installed but there are around 3 or 4 resistors that are the wrong size. I just need to determine if all the connections are in the right place or not before I change these resistors
On the can caps, I went ahead and ordered the hayseed caps to avoid the headache of restuffing. Just gtta wait for them to get here then I can finish up this job.
