Hey guys. The restore of my 299 went so well, I decided to tackle my LK-48-B. Of course I hit a hitch right away: I can’t seem to get low enough bias voltage to pin 2 of the 7189s.
First I installed 10Ω cathode resistors and test jacks so that I could easily see how the tubes were biased. To do this, I replaced the common 10Ω 2W resistor on pin 3 of each channel with 2 10Ω 1/4W resistors and clipped the leads to the old bias switch. I immediately noticed that the highest possible bias voltage across the sensing resistors was only about 0.11V (I was expecting 0.20V and higher).
So I went ahead and replaced the selenium rectifier, dropping resistor (put in a 33Ω 5W) and the 100uF bias caps. At 117V input, this gives me -58.1V after the bridge, -44.7 at the first 12AX7 and -48.7V up to the bias pots. However, the lowest that I can dial the pin 2 voltage is -16.5V resulting in only 0.11mA current draw per tube. If my understanding is correct, I want approx 0.23mA draw and need -15V or less to get there. Right?
I’ve attached the relevant part of the schematic with my changes in red and the voltages in blue. I can see two possible approaches to lower the -16.5V at pin 2: a) raise the value of the 10K resistor (R211) to lower the voltage up to the bias pots, or b) lower the value of the bias-pots-to-ground 150K resistor (R214) that I believe will lower the bottom end of the pin 2 range.
Or is there something else going on here? Did I mention that I’m pretty new at this.
Any advice will be much appreciated!
Edit: corrected schematic
