Could I make the proper replacement out of a 10K ohm, with resistors to bring it in to spec:
10K OHM DUAL 2 WATT LINEAR CLAROSTAT POTENTIOMETER LONG SHAFT NOS 1 PCS.
Or just use a 100 ohm pot, with a resistor like xraytonyb said he did:
100 Ohm 5 Watt Wire Wound, Long Shaft Potentiometer - Centralab WW101
While ideally it would be great to have a 75 ohm match, the 100 ohm solution should be good enough. The idea is to keep a fairly constant ohmic value (impedance) as you go from one end to the other.
This is from the SG165 schematic. Look at what happens to each element at the shaft is turned. Full clockwise R10A is bypassed but R10B is full resistance.
Go counterclockwise and you get the opposite effect. In the full CCW position, R10B is a short to ground so no output.
