Nice job on getting this classic back to life and working well again.
Why thank you Kent! So with the Sencore SG165, I am now open for business for alignments.
Resume
In high school took electricity for one year with a gifted Navy radioman, what an excellent teacher
In high school took electronics for one year with that same gifted Navy radioman, still an excellent teacher, very lucky to have him
Had the opportunity to get a class D radiotelephone license, do not know if it is current
Completed a bachelors in bioengineering at the University of Illinois wonderful teachers here
Worked at Motorola as an intern in the crystals division in Schaumburg IL
In my fifties worked on four NRI tube radios starting with AM alignments using a 455Hz sine wave generator made by Knight kit
In my middle fifties to early 60s worked on many tuners;
Adcom GFT-2 4 electrolytic replaced on 6-6-15; replaced fuse with ¼ amp slow blow SB
Adcom GFT-555
Adcom GFT-555
Carver TX11
Dynaco AF6
Dynaco FM3 aligned on 11-4-20 stereophile class B has PEC upgrades and 4 capacitor
upgrades uses diode matrix and LC IF
Dynaco FM3 aligned on 11-7-20 stereophile class B has PEC upgrades and 4 capacitor
Dynaco FM3
Dynaco FM5 modified chip MPX
Dynaco FM5 stock
Kenwood KT5500 stock new light bulbs times 3
Kenwood KT5500 stock new light bulbs times 1 wired in series!
Kenwood KT7500 bulbs, OPA2604, AD823, then OPA627BP, polypropylenes Schottkeys, bypassed 75us switch
Knight KG795 has 4 gangs and LCIF and diode matrix MPX
KLH 18 WB uses diode matrix and LC IF stereophile class B
Needed meter surgery and meter face is upside down, gluing veneer
Mcintosh MR71 needed MPX work (lots) and silicon rectifiers and 6BM4A stereophile class A uses diode matrix and LC IF
Optonica ST3636 5 gang tuner
Philips AH6731 needed adjustment of center tune meter number 7 on fm tuner info
LC IF but chip MPX
Pioneer TX8100 aligned in 2008 WB black cabinet
Pioneer TX9100 modified polypropylenes WB swap cabinet; now walnut cabinet
Pioneer TX9800 feet replaced modified with Schottkys and 2 polypropylenes SB
Pioneer TX-9500 stock WB
Revox B760 needed a transistor and capacitor for power supply, meter transplant, alignment, 3 watt lamp, 4 24 volt lamps, 2 CA3053 can ICs, ceramic cap,
painted grey, toggle switch repair LCIF chip MPX number 8 on fm tuner info
Sansui TU-555 WB uses diode matrix and LC IF
Sansui TU-317 just moved tuning cap a little and it unseized
Sansui TU-517 highly modified with polypropylenes and Schottkeys
Sansui TU-717 modified polypropylenes 90 v Schottkys
Sansui TU-717 stock repaired with zener diode
Sansui TU-717 stock with hazy plastic two new transistors bad EC junction in small signal transistor
Scott LT112B broadcast monitor tuner sleeper uses diode matrix and LC IF
Tivoli Audio Model Two Stereophile class D 2007
Tivoli Audio Model One Stereophile class D 2014
In 2020 bought 10 tube tuners and 3 transistor tuners from facebook marketplace fixed them up and sold all but the venerable Scott LT112B because that is a great keeper tuner
So give me your tuners to work on for alignments! with bad RF sections, bad IF sections, bad discriminators, bad MPX sections, bad audio sections. I have a Sencore SG165 signal generator for MPX alignments, a Tektronix 150mhz four channel scope, several other Knight and Eico signal generators, Radioshack and B and K frequency counters, Sencore cricket transistor testers, RCA senior voltohmyst VTVM for discriminator alignments, Fluke multimeters. B and K capacitance meter, Tiny SA spectrum analyzer. I just enjoy this as a hobby and will help others on Audiokarma, now that I may be qualified.
