Pink Floyd
Empire Pool
Wembly, London, UK
November 16, 1974
SBD + AUD Matrix Mix (60%-SBD/40%-AUD)
01 [02:08] Speak To Me
02 [03:02] Breathe
03 [05:04] On the Run
04 [06:35] Time
05 [06:48] The Great Gig In The Sky
06 [08:14] Money
07 [07:46] Us And Them
08 [07:42] Any Colour You Like
09 [03:39] Brain Damage
10 [02:05] Eclipse
Encore
11 [23:28] Echoes
TT [76:31]
Source Info
SBD
Pre FM Master Reel (SBD) > DAT > ? > SHN
Recorded by BBC Radio One broadcasted on the Alan Freeman
Show on 11th January 1975. This is taken from the original
pre-broadcast master tapes.
AUD
Unknow AUD Recording > ? > DAT > SHN
This is likely off cassette masters.
Tech Notes
SHNs were decoded to wave and SF 6.0 was used to reassemble
the tracks back to 1 long wave. CEP2.0 was used to align &
synch both of the sources. CEP2.0 used to adjust the volume
for the SBD & AUD. This is a 65% SBD, 35% AUD mix.
- Mixed by
dan@am-dig.com
- FLAC conversion 01-APR-2005
- Artwork by
dan@am-dig.com 300dpi - For best results
print at the highest resolution onto glossy photo paper.
Design for use with a clear slim single jewel case.
- Special thanks to unknown artist that helped with lots
of the images used in this artwork.
Notes
d1t01 The line "I've been mad for ****ing years" in Speak To Me
was removed from the Pre FM (SBD) source. This was not cut out
as the length of the song was still the same as the AUD. I tried
a number of edits to mix that line from the AUD into the SBD
source. I could not come up with an edit I considered smooth.
I was able to perform the same edit of this line on the AUD
source with a smooth and natural result. So this line has been
removed from both the SBD and the AUD source. This is smooth
and most likely undetectable.
d1t05 The Pre FM (SBD) source was missing 3.875 seconds between
The Great Gig In The Sky and Money. The AUD was the trimmed
accordingly to match. Being at the repetitive portion on the
end of the song, this is smooth and most likely undetectable.
d1t08 The AUD source cuts at 41:07.515 and is missing 1:36.33
of Any Colour You Like. I used the Pre FM (SBD) source mixed
with a repeating crowd cheer portion from the AUD recording to
add depth. I then applied a 1:46.333 patch with 5 second
crossfades on each end. The result is good but as this is a
source change it is still somewhat noticeable.
d1t09 You can get a good feel for the effect of sound travel
during the line "The lunatic is on the grass.". The sound
travel results in a small echo on the AUD source and can be
heard in the rear channels on the 5.1 and the matrix mix.
This is very interesting.
d1t10 The Pre FM (SBD) has a long portion of cheering and
tuning prior to the encore Echoes. Unfortunately this was
missing from the AUD source. The SBD was trimmed to match
and both sources has multiple edits, mixing and crossfades
were performed to keep the flow btwn the last song and the
encore sounding as natural as possible. The result was good
and this is smooth and most likely undetectable.
