I've inherited a couple hundred L.P.'s. They have to be shipped a couple thousand kilometers.
What is the safest form of packaging for records. Any advice?
I was a furniture mover in college and packed a heck of a lot of these "book cartons," which were sized to hold a limited number of heavy books or LPs. But they can also split open if not handled carefully. If the LPs are really valuable (either in monetary or sentimental reasons), I would suggest using cartons like these and then having a small, sturdy crate built to frame each of the cartons. It will cost you more, but the LPs should arrive in one piece. It will probably also prompt the transport firm to use a hand truck and not try to carry (and drop) them.In the US, UHaul supplies a box that is 12.5 inches by 12.5 inches by 16 inches and perfect for packing several albums with no empty space. Fully packed they are heavy, though, so not sure what the cost to ship would be.
Would you really want to drill a bunch of screw holes into a $100 Mapleshade oak LP shelf?They're kind of like this, which could easily be strengthened by screwing plywood faces onto all sides essentially as sheathing.
That one's from Sleeve City. Here's another one, from mapleshadestore.com
So long as you use substantial wood screws (with pre-drilling) I daresay that 5/8 plywood sheathing would be all you'd need to add in order to convert these into practical long-distance shipping containers. I'd probably reinforce the corners too (on top of the sheathing). Doubtless someone here has already done this and knows more about it than I do, though.
One additional thought: an inner lining and/or outer coating might help when they're left out in the rain, which might well happen somewhere along the line. And (though opinions vary) if you're shipping in summer time you may want to consider the likelihood that they'll be subjected to extreme heat, which can damage vinyl records and other living things.
I sure as hell wouldn't.![]()
Where are you located? Or should I say where are the records?Thanks for your suggestion, @0Hz. But I'm looking at 100's of L.P.'s and I'm thinking more along the lines of crates, or at least very sturdy boxes, that can fit perhaps 40 or 50 L.P.'s each. But I can't find anything that fits the bill through my searches.
