Congr. Restorer-john
:scratch2: Hmm, I start to also think of baby Son, it started to be very monotonous, working and working and nothing to do more in hifi now seriously.
My last optimisation occured accidentally. While I connected the cables to xa7, I moved it a bit, then when I was relocating it, I saw noticable sound change. Then I continued to adjust the feet and location carefully listening to the sound, and....
SONY XA7ES OWNERS!!! This iron bulk is much much more sensitive to location than my turntable. I have discovered that when I put 5650 on top of xa7, and when its location is changed it played better, but this was not this much strong up to now. The reviews also tell this seriously but I never tested this, using sink etc. I lately also discovered that my kenwood tt with bluepoint no.2 also loves the corners and outer borders of my big black wooden table. I tested this for xa7. I have always told an anbelievable sound by 5650 that made listener shut up and simply let shocked when they heard this much resolution. FINALLY I REACHED TO THIS. It is unbelievable resolution by xa7 equaling to vinyl, even beating on some, that 5650 is able to pass this but no other amplifer. I tested the 5650 itself too, yes it showed this as it showed 2 years ago being less impresive with optimised ears now. BUT currently the sound I get from system is much much more than this. There is now Day and Night difference between 5650pre or tae88 and my buffered passive usage. Maybe this is why I get serious difference from xa7 now by location and feet adjustment, shows the difference much more. Tae88 owners, If you are able to find a ladder type 100k attenuator with vishay dale resistors, use it with buffered recout of tae88. buffer prevents missing drive. The resulting resolution, dynamics, clarity, timing, air, bass quality, everything is much better than tae88 line stage. tae88 lien stage sounds closed, suppressed, limited, distorsive, lacking details seriously and unmusical. If tae900 is noticably better and exclusive or taer1 or cello is a bit more of it, then the day and night difference of this usage more probably beats them all easily. This pot is 50$ ! I am not using tae88 line stage anymore. I dont need a line stage that is able to drive everything with 10 stage, it must drive only my amp, also i dont need output level, balance, muting. Recout buffer is fantastic and does its job. The gone is tiny bit bass weight and tiny bit energy impression on a couple of high end overprocessed today's jazz cdroms, but bass is now resonating. Energy loss is due to my very long interconnects grup in serial. The coming is on the other hand out of this world. If not! and you already have the sony players, please suspect speakers.... :thmbsp: this is the best sound I have ever heard. I am happy with my system, finally.. I marked the locations of even furnitures to floor, I am touching to nothing.
