Ok, you got it.The SIT
The static induction transistor is a three terminal, vertical current flow, semiconductor device that most closely resembles a solid state version of the triode vacuum tube. It is a voltage controlled device and is one version of a field effect transistor (FET), where the voltage on the gate controls the current flow between the drain and source regions. It’s a special design of a junction field-effect transistor (JFET) and were originally referred to as vertical field effect transistors (VFET). They are capable of high-speed and high-power operation, with low distortion and low noise.
It is a vertical structure device with short multi-channels. The device was originally known as a VFET, with V being short for vertical. Being a vertical device, the SIT structure offers advantages in higher breakdown voltages than a conventional FET. For the SIT, the breakdown voltage is not limited by the surface breakdown between gate and drain, allowing it to operate at a very high current and voltage.
The most obvious differences between the SIT and other FET’s is both its vertical structure and that it uses two internal gate contacts. Most FET’s have a single gate that controls current flow in a channel that is parallel to the gates plane. The SIT is a vertical device, with two gate contacts on opposing sides of its channel. It is this vertical current flow and additional gate control that causes the SIT to exhibit non-saturating current characteristics similar to triode vacuum tubes when under high voltage gate bias conditions. It is this unique characteristic that sets it apart from other FET’s.
It is true primarily for the first generation Sony amps.I seem to recall learning that some of these VFET amps could NOT be brought up on a Variac or you would blow the outputs.
Are any of these like that and if it’s true, why?
(I suppose I could try searching it out myself but then we wouldn’t learn anything!)
Just to be clear, are you saying that this only applies to first gen Sonys?It is true for the first generation Sony amps.
vfets are depletion devices that are fully ON and if Vds is applied without first applying Vgs, bias the transistors/ to turn them off, they would instantly fry.
The first gen Sonys require full mains voltage to deliver Vgs potential immediately after power up.
yes but not tested or assessed on the Hitachi, Victor and Sansui. I added additional details to my prior message to dispel confusion.Just to be clear, are you saying that this only applies to first gen Sonys?![]()
No confusion on my part. But there might be for some of the less experienced. To my thinking it's always good to be specific when it comes to these sonic beauties ...yes but not tested or assessed on the Hitachi, Victor and Sansui. I added additional details to my prior message to dispel confusion.
Always good insights from you @theophileI mentioned the B1a on this forum many years ago. I had stumbled upon a mention somehow. Anyway I mentioned it once as an aside.
I am so thrilled to see you have ownership of this. Congratulations
That is up for debate. A simpler circuit with no feedback means low gain, low power (with high distortion / THD that starts to get noticeable above a few watts), thus a specialized use. If one is interested in that type of amp I would recommend the wonderful FirstWatt offerings from Nelson Pass. I think the latest one is FW SIT-4 that uses Tokin transistors, which is available for sale now.With the excellent liearity of the SIT transistor type It has occured to many that a much simpler circuit like a Class A no negative feedback single ended circuit could be applied to the technology. It is not altogether the aim of all amplifier designers to go with such a hair shirt approach but a linear power transistor makes the idea less nebulous.
SemiSouth tried and supplied them to Nelso Pass for the FW amps (except the SIT-4)Kudos to that Japanese ex-V-Fet designer who said we can't just abandon this. The number one thing needed is for a new manufacturer to step up and produce a decent batch of Power SITs. I cannot see how there would not be a market for products incorporating them.
With the exception of Yamaha B1, all Japanese vfet amps including the B-1a are very much wire with gain (read: extremely transparent, detailed / very low THD)A thought that has occurred to me is to incorporate a SIT in place of the tubes in a David Berning type circuit. That would be interesting I feel. Although I haven't used one in years. I lived and loved mine every day for many years. Very fondly remembered and something I would gladly revisit if I had my life over.
And I would agree with all of thatI like a combination of 'nested negative feedback' with a compensatory amount of global negative feedback. That's usually a great way to do it. The thing about a very linear device is that it gives the designer more options. The simpler open loop circuits though limited in their practical application can be applied to 'per driver' function in a diy active loudspeaker. Removing the reactive passive crossover elements and passing the signal directly to the driver in an active configuration frees the stage from a fair bit of what it doesn't like.
I'm generally a fan of getting rid of as much as can be shaved away from the signal path. I do understand that simple can be too simple but in general where there is robustness and the ability to do the work, less reveals more.
I have a car amp that says V-fet on itI remember it was a black amp with no vu-meters and written on it V-FET Twin Drive and someting about Full Symetrical or something like thisthe sound was good,punchy bass and crystal clear all the way up to full power
I've listened to nothing but Active speakers, at home, for the last 21 or so years. Initially diy. Which meant I could experiment with brand name high fidelity amps driving my active loudspeakers. Hence the Yamaha B-2. It sounds great in a passive system but have you heard it in an active system? It's a different application and an education to hear it used in this way.And I would agree with all of that
I love the interest in the right type of HiFi ......but I thought your soul was sold to active speakers![]()
It was a pleasure to bring it back to life for you and thanks to your generous contribution at the time, a couple of other B-1's have since lived on too.My Vint Age restored B-1:
Yes indeed! Truly sonic bliss, both yesteryear and today.that's a thing...simply amazing....
