Shure cartridge question
geph0007
AK Member
I have a Shure M91GD with a 8X stylus. Is this a good match or a good stylus or should I put a different stylus on this and if so which one is best for this unit.? Thanks
The Shure M91GD was originally equipped with a 0.6 mil conical stylus. What is a 8x ?
It looks like you have a stylus for a Radio Shack by Shure cartridge on your M91. There are many choices for the M91.
Thanks
The link does not really settle on a good one One guys mentions it sucks? I also have a M73PED which says Hi Track but that must be step down from the 91GD The question really is what is the 8x stylus ? i know it was for RS but compared to what else?
Thanks
Do you mean M75 ? I need to look up the 'PED'. First, let's be sure of what you have. There is no 'best' only what is best for you. There are conicals, ellipticals, hyperellipticals, line contacts, I bet TurntableNeedles has Shibata's for those two cartridges and JICO may have SAS for those models. What turntable do you use them with ? There is always someone who says something sucks. LOL.
I read the 'suck' comment. The poster probably got a bad one from when they were being made in Mexico. Shure no longer makes cartridges or needles. And the EVG that she was referring to were sourced from JICO back then. That sourcing ended in the 4th QTR 2017.
Found '
"There are two Pacific M73 cartridge - the M73PE which is not a M75 but a M31 and the M73PED which is a M75".
So you have two popular cartridges; the Shure M91 and M75. You can buy from The Voice of Music as Nashou66 stated.
The M91 body will take a laundry list of different nails, so really it depends what you're putting it on and what you are playing with it. M75, M91, M93 and I think the original V15? Or is it the V15-II? One of those. I want to say there is another one as well. For each of those families you get a number of options in terms of stylus shape and tracking force.
N75 and VN15E are 'officially' interchangeable. So...N75 and V15 II. It can be confusing because the stylus for the original V15 is VN2E. Backwards of any logic.
Thanks
The 8X stylus was another name for an Ne95E, a .2 x .7 mil bonded, high compliance stylus using a rather thick cantilever. I used some back in those days and they were typical of bonded economy styli. Not terribly long lasting and rather poor performing compared to a nude ED stylus or even the heavier tracking EJs.
Hi great responses. I should mention I did work in the audio bizz back in the day also and also did some product trainer for others but we only carried AT, Empire and Orotfon so my Shure knowledge has holes in it hence the reason I am asking.
The one is an M73PED (not 75) which I guess is probably not worth messy with as the M91GD would be more desirable?
Granted I need to read through these posts again but If one went with the M91GD what would be the best stylus other then the original that one could? put on it
The next question is would it be better the a Signet MR 5 Basic and Basic stylus??
What’s your stylus budget? Less than $50, $51-$150, $150+?
Thank you for the pics. There are many of you who are great at this. Is that M73PED an M75 ? To me it looks more like an M75 than an M31.
The Signet is going to sound different than the Shures. You may prefer one sound signature over the other. You might want to keep and use all three and enjoy the differences. I cannot pick one for you. You'll get more responses.
@Wolfie62 Can you help ?
The M73 is a house branded cartridge for Pacific Audio. It is the same as the M75 which is also the same as the M91 except for the plastic mount which is used to limit stylus mixing between families. I'd suggest avoiding high compliance styli unless your tonearm is really low mass, as in, less than 9 grams. Instead, if your records are in mint condition, get a good quality medium compliance .3 x .7 elliptical similar to the original EJ stylus. If your records are in used condition then the medium compliance . 6 spherical is also a good option. PhxJohn can probably provide details about nude mount EVG .3 ellipticals which I haven't yet used but seem to be well received.
The genuine ATN120E is an excellent stylus. It will cost more than the Shure replacements and will probably also have a bit brighter presentation.
