Stanton681EEES
Addicted Member
What I'm asking is if you have a P mount adapter from a Shure cartridge would it fit an Audio Technica P mount body? Or the other way around the P mount from the AT would it fit the Shure body?
JVC (Japan Victor Co.) wasn't a Matsushita brand. And they continued to produce 1/2" straight arms well into the '80s before doing any p-mounts. Nowhere near like Technics that made all it's straight arms p-mount.
Wow, sorry, Don, didn't know that about Matsushita.Actually, if you look up its history, it has been majority owned by Matsushita, since 1953. http://en.wikipedia.org/wiki/JVC According to my turntable guides, which date from 1979-85, JVC was second behind Technics in take up of the P-mount, although as you say, not all their turntables used it, and very little was shared between JVC and Technics/Panasonic.
-Don
Some p-mount adapters are taller than others. It might be possible for a taller p-mount cartridge to not fit in a shorter adapter. Can't say I've seen it happen, though.
I think the mount itself was exactly the same for all TP4s, but since they were actually meant to be used directly in tonearms, not in the adaptors, the actual upper cartridge body dimensions weren't specified, so not all adaptors work with all cartridges.
And people lost the screws, and if the nut was not trapped, they lost the nuts too, and then just used anything lying around (and I don't mean to condemn them, since I'm one of them). Why they used such an oddly thin screw with an usual pitch is puzzling...
I think the mount itself was exactly the same for all TP4s, but since they were actually meant to be used directly in tonearms, not in the adaptors, the actual upper cartridge body dimensions weren't specified, so not all adaptors work with all cartridges...
The only thing that bothers me about the T4P is I have to take its word that the tracking and antiskate are @ 1.25 (when in a real T4P turntable/tonearm.) Just wish I could easily double-check! :yes:
That's easy to do. There are plenty of stylus force gauges available - Thorens make a very cheap one...The anti-skating is easily checked with a test record...
My Technics SLJ3 is completely automatic, doesn't even give me access to the cartridge when the lid is closed or open. Pulls it up tight to the lid and returns home when I lift the lid and won't come out until I close the lid and press a function to start. I will be on the lookout for a test record, though, thanks Don!
