Dang you work fast. Congrats to the proud papa.
No way to dampen it?
Is it running really hot? See if it buzzes without a load. Maybe bad or faulty cap is loading it too much.
Randy
Maybe try rubber washers under the mounting ears or playing with the tightness of the screws holding the bells on. I've had noisy transformers shut up by tweaking those screws before, and not always by making them tighter.
Byrd, it Would actually be the other way around there.
4ohm tap would be 8, 8ohm would be 16, an 16 would be 32.
Now if you had enough current to run 6L6's or EL34's then 5K
primary would do pretty well there and have the "normal" taps.
By the way beautiful construction, that is a great looking amp. :thmbsp:
