This thing is getting heavy!
That's because you built it like a tank:tresbon:
On some of the first photos you show the octal-sockets with mounting-rings attached for under-chassis mounting.
You actually ended up with top-mounting.
Is there a reason for that?
Personally I prefer out-of-sight mounting but yours look OK as is.
Any thoughts on the actual 6V6 schematic?
...or on the two remaining amp's (Mid & Bass amp's)
I can't help thinking if the 'small' Treble-amp is a tank ...what's waiting?
rgds,
/tri-comp
I don't believe there are supposed to be wires sticking through the middle of the tube sockets![]()
Looks good. I kinda like the idea of the RCA inputs on the back on the same side as the speaker jack. Sort of makes sense which input feeds which set of outputs. I'm also assuming the posts are for 4,8,16 ohm taps ?
Very nice Sir. Stunning woodwork.
I've had a machinist do some work for me, and it wasn't very clean, so I've been cautious. I don't want to argue with you here, because I'm sure I'm just being irrational.
What do you mean "clamping" Sir? I have a PP 807 chassis that needs anodized and I am going between the blue you used, red, and gold. They all look so perdddy
Gotch'ya. It is worth the wait.
I like the clean look using glue to attach the back plate. Now the fun begins.
