Small gear on Gear Assembly #97 – SFUP-172-51A has a crack on the radius, a common failing. Extends from center hole to edge.
AudioKarma.org member Hemi Ram (Rich) posted that he found a replacement gear in NY and made the repair.
Rich cut the old crumbling gear off and pressed the new gear onto the metal shaft. The plastic (Acetal) gear only needs the 7mm hub projection reduced to about half that size. Thanks Rich for all your help!!
I live in neighboring state (NJ), ordered a few and was charged $3.95 shipping. Here is the company info, I received the order in two days;
SDP/SI (Stock Drive Products/ Sterling Instrument), (1-800-819-8900/ 516-328-3300 ext 491), 2010 Jericho Turnpike, Box 5416, New Hyde Park, NY 11042-5416. Web site;
https://sdp-si.com/web/html/direct.htm
Enter Part # in search window, click on part #, then click 'Catalog Page' for gears & specs)
Part# A1M2MYZ05032; Module 0.5, 32 Teeth, 20degree Pressure Angle, Acetal /No Insert Spur Gear. $1.36 each.
In its mounted position, I removed two screws removed for clearance. I pressed / wedged my old gear off using a few odd tools. Unless you have experience doing it without a small gear press, I suggest you cut it off with a large diagonal wire cutter. I used a wooden dowel to hold the gear and a Band-saw to cut off less than half of the 7mm Hub projection. I used a large pair of needle nose or duck billed pliers, (a little lube) to press gear onto splined shaft. On the backside of this gear is the rubber/neoprene drive roller that moves the tone arm laterally. Roller can deteriorate, additionally the roller and adjacent surface must be free of grease. Rich noted that #60 neoprene will work. I've included some Pics of my repair.
For the sake of Engine Search effectiveness, I will also post today my repair of the Pitch Control LEDs on my SL1600mk2. IC427 was the offender and CD4011BEE4 (Mouser Elec. @ .50¢) was the cure.
