petehall347
the brandy coffee man
multilayer boards are sometimes rather difficult to rework . unlike single layer .
add solder to it. it will mix in with the old and make the heat flow thruout for easier removal.I noticed that some of the older solder takes a blow torch to get it to melt
yes they are. i have different ways of dealing with different situations.multilayer boards are sometimes rather difficult to rework . unlike single layer .
i've debated buying a hot air station. the last time, hot tweezers won out.mine also has hot air and can be used to preheat the board a little .
Why?replacing the resistors on this CD player.
I've been soldering for a some time now. In fact even on several McIntosh pieces. I really don't remember any of them having boards like this one before. I have a couple McIntosh pre-amplifiers, several McIntosh CD players, an McIntosh amplifier a McIntosh subwoofer and I have already worked on all of them. But then, I only re-capped, cleaned, lubricated them but never replaced resistors on them. That's probably why I never noticed these boards being so tight before. I can't really say I have any trashed Mcintosh equipment that isn't as good as the one I'm working on, so I guess this one is as good as any to practice on. I am almost finished with this board and I haven't had any problems with it yet (I did say yet). Once I figured out how to go about it, it was only a matter of taking my time. I know that I would MUCH rather take my time than have to fix traces. One other thing I have noticed is that a few of these resistors are slightly out of tolerance, so I figure if I want to keep them all working as long as possible, I better consider replacing all the resistors now. Either all my Mac's will be dead and buried or I might be pretty good at replacing resistors by the time I'm finished with them. Another thing I noticed about this mcIntosh board is that once you take the old solder off, reading the traces is easy. I know when one is attached to another. I have learned a new respect for McIntosh. I've been listening all day to a couple MAC's while I was working on this one and I could (almost) hear them cheering me on.practice on something you don't care about first
There are some items that I figure I should only heat up and solder as fast as I can, yet try to make sure I have a good solder and I don't damage the component. For some reason, small transistors are one of them.I've found that sometimes (very often, in my case) lightly and briefly touching the solder to the tip of the iron is not really a problem, and for me, it's preferable to holding the iron against the component and waiting for something to happen.
I once posted and titled it: Ask one question, get ten different answers. I figure what works for one person may not work for another. Not a big deal.I don't expect everyone to agree with me
yes it is always what works for you no matter what anyone else tells youI once posted and titled it: Ask one question, get ten different answers. I figure what works for one person may not work for another. Not a big deal.
Well, I watched lesson #1 Basic soldering and it had a lot of good information. I did a few more resistors this morning after I turned my iron up a little and it made a big difference, On most of them it cut my time in about half and the solder is coming out a lot faster. I forgot to try the flux, that will be next. I had one resistor that I'm not sure I would have even gotten out if I hadn't turn the heat up. It was really stuck in there.
you need a set of these or similarmrhorst, I use a solder ball also, I really like it. It's easy to use and it keeps my tip shiny. At this point on this board I have a few resistors that are boxed in and really tight together so there is no way to try to pry them out from above. As you know, I have to pull the resistor from above, push down on the board while applying heat to the trace on the bottom. It wouldn't be so bad if they went so tight. I have to moderate the pull or I can tear the trace out. I have to wait until they start to move.
arts, I going to move to a smaller diameter solder and try that.
look at the 2nd tool from right. the bottom. the hook. hook it under the lead and pull after the pad is heatedAlready have them. With this board, the tweezers will not grip the resistor hard enough to pull out. Sometimes (if they fit) I will use them to pry. These resistors are really stubborn, but patience is my best weapon.
if there are traces on both sides, there are likely plated through holes so be careful. Its pretty easy to wreck the plated through hole when removing old parts.Or lacking of... Before I retired I worked at a place where there was about 500-600 men and women who used to solder circuit boards. We did have a few flow soldering stations, but mostly they were soldered by hand. I used to always watch them and pick their brains. That's where my education in soldering began. That was many years ago. I also had a couple of friends who would teach me about working on radios, testing tubes etc. for several years. Now, I have a lot of radios and stereo equipment that has been sitting and waiting to see if I can get lucky to revive one or two. Obviously, my skills are limited. Any way, I have a McIntosh 7007 CD player that after several years of loyal service seems to have been damaged (along with another one) by another piece of audio equipment that went died and tried to them with it. So now I figure being I live out in the sticks and I already have replaced all the damaged audio equipment, so my music is still alive, finding a good tech. is getting harder and harder and honestly, I don't want to put all the $$$ into them that some techs. want. So, now I figure I'll practice my soldering skills replacing the resistors on this CD player. Right off the bat, I noticed that someone had replaced a couple of resistors and didn't seem to be a very good job of it. That's also when I noticed that this circuit board has traces on both sides of the board. Personally, I found that impressive. Thing is, the fit for resistors is tight...so I have to be very patient and very careful. I switched my soldering tip to a pointy one, I now spend a lot of time trying to get the solder out on both sides and I used the heat from the soldering tip to pry the resisters out the possible. I find being patient is a lot better than having to fix traces. If any of you guys have any tips or advice it would be appreciated.
