arts
Addicted Member
there is at least one record with two.
Jack White, Lazaretto
No, just a tired old guy posting stuff that I find interesting. I’m not suggesting 100 hour break in period for speaker cables or anything like that.Relax pal,I'm asking a question not trying to make a point.I thought you were heading toward some flat Earth bullshit.
Related:
On average, how many grooves are on one side of a 12 inch LP record (plus or minus 20)?
I think Calvin is contemplating the constantly decreasing sampling rate.View attachment 2740600
that's interesting from a different perspective: Earth rotation. in theory the equator goes way faster than, lets say, Alaska. the 'speed' DIFFERENCE can be 600mph between countries, even within America. think about it. do you feel a speed difference between 30mph and 100mph when driving a car?
It's not flat?Relax pal,I'm asking a question not trying to make a point.I thought you were heading toward some flat Earth bullshit.
The average LP has about 1,500 feet (460 m; 0.28 mi) of groove on each side. The average tangential needle speed relative to the disc surface is approximately 1 mile per hour (1.6 km/h; 0.45 m/s). It travels fastest on the outside edge.
Sorry I should have said,SPOILER ALERT....It's not flat?![]()
Just chance. Nothing calculated or scientific about it. I believe it was just pulled out of the air.I've always wondered why they decided to make the defacto speed exactly 1/3rd of 100 RPM?
To match up the film with sound, a company called Vitaphone introduced a system that used a standard 3600 RPM motor to rotate a soundtrack disc. To make the audio last the same 11 minutes, the math dictated that the motor be geared down to 108:1. That gives us a rotational speed of 33.33 RPM.I've always wondered why they decided to make the defacto speed exactly 1/3rd of 100 RPM?
I don't know.. Kinda hard to believe that..Just chance. Nothing calculated or scientific about it.
That actually makes senseTo match up the film with sound, a company called Vitaphone introduced a system that used a standard 3600 RPM motor to rotate a soundtrack disc. To make the audio last the same 11 minutes, the math dictated that the motor be geared down to 108:1. That gives us a rotational speed of 33.33 RPM.
Early stereo record, two tonearms, tracking independent left and right channel grooves.
Depends on whether I'm riding in an AMG Mercedes or in a Ford Festiva.Only if I stick my head out of the window like a dog. Otherwise, they both feel the same.
But I love Calvin & Hobbs.
Ever heard of the phrase "inertial frame of reference"? What that means is that unless you are subject to an external applied force which creates acceleration you are in an "inertial frame of reference" and cannot detect the difference between any "velocity" that you might have.
If you are in a closed box you absolutely cannot tell the difference between any supposed "velocity" that you might have versus any other.
That's also what allows us to declare that gravity is not in fact a force as when you are in free fall and in your own particular inertial frame of reference you cannot detect it except by observing something in a different inertial frame of reference. In essence you are travelling along something called a geodesic where you are simply following the curvature of spacetime, and that curvature is created mostly by changes in, effectively, the rate of flow of time due to the presence of mass.
Really spooky stuff...
