Redboy
a few good watts
Yes!! :yes:How about something like this?
I think they're purdy. You could really just leave them as they are and I'd be impressed. (No need to bolt any electrical components to them or anything!)I spent a little time experimenting with sandpaper on the plates today. (...)
What do you think?
I think that would work for me. I have been meaning to bring you a couple of samples of different finishes If you wish to do some more experimenting with those plates (and you may have already done this), try hitting them with a grit that is about a couple of hundred higher, i.e. a finer grit after you have established the texture that you want with the brushed finish. That tends to knock down the edges of the grain and develops a more uniform aspect.I spent a little time experimenting with sandpaper on the plates today. I think I'll leave them raw, with a faux brushed finish like this...
What do you think?
Ah, was it a "Timeslaver" I mean Timesaver machine?I've used one of those at an old shop I used to work at. It was pretty crazy if you ran the first part and the belt was too low. You would hope the belt wouldn't fly apart before you let up on the belt pressure.
It took a little playing around, but it ended up being pretty simple, really. Lay a sheet of coarse sandpaper face side up on a scrap of carpet and run the aluminum piece back and forth over it. I used the edge of the other plate as a guide, sliding the working piece alongside the long edge to keep the grain straight. Use long strokes, running the plate off the edge of the sandpaper occasionally to avoid visible "stop marks."So how did you go about graining those parts, Nate?
Thanks for the tip, Lance! I did that, and they look even better now!If you wish to do some more experimenting with those plates (and you may have already done this), try hitting them with a grit that is about a couple of hundred higher, i.e. a finer grit after you have established the texture that you want with the brushed finish. That tends to knock down the edges of the grain and develops a more uniform aspect.
Yeah, it turned out pretty well.Cool!
That top plate looks real nice Nate.
Hey Stan, the caps are made by ASC, and they're available from some of the big electronics houses in a 440V rating. I got mine from Allied Electronics. They're also available in higher voltage ratings from Angela Instruments and Parts Connexion, I think.
Try the technique outlined in that thread when you next use the hole saws. It's a bit of fussing around to get everything set up and aligned properly, but it's a world of difference. Highly recommended!
