People always compare things.
Unfortunately very few of them list what test conditions they used to obtain their result, and virtually none of them provide any measurements.
Take it all with a grain of salt.
Determine what power level you need.
Use power tubes which get you to that power level using the topology of your choice. Run them about 70 to 80% of maximum disapation and replace them when they get weak.
There's no magic to it.
There's a lot of opinions floating about which are completely irrelevant because they do not come with test conditions and often the tests are performed on worn out antique equipment, then used by the uninitiated to make grand proclamations about how a tube sounds.
Tubes don't really have much of a sound.
Speakers have a sound, cartridges have a sound, but tubes, they just do their job, or they don't.
Don't read too deep into the tube rolling topic, you'll go insane.
Instead find some technical literature about how tubes work, how to set up a power stage and how to minimize distortion by basing hot and balancing your phase inverter. You'll be lightyears ahead of those who only know how to roll tubes. Unfortunately, the rollers will always be louder and there will be a lot of them spreading their noise.
I assumed all understood I was asking if there is a sonic difference between the TS 6550 vs the
TS KT120 in the same circuit, under the same conditions. I apologize for not being more clear.
I do not want my monoblocks sounding different with the KT120s as the TS 6550 is perfect for my design.
Pertaining to the quote above:
1. Different tubes certainly do have a "sound" quality in a high quality amplifier for several reasons.
A. The harmonic structure can be and is different between brands, and even different tubes of the same manufacturer.
A chinese KT88 has a different harmonic structure, and twice the HD of a Winged C KT88 under the same conditions.
B. One has to also be aware of different materials and material quality.
I won't go any deeper.
2. When comparing tubes, the system is the same, so the conditions are basically the same and cancels out of the equation.
Now if the tube's characteristics are quite different when comparing, that needs to be considered.
3. If one tube sounds better, then there is a sonic difference. I am Not requesting which sounds best, but
if there is a sonic difference between the new Tung Sol 6550 and their KT120. I may be
able to design around a different "sound", but not necessarily.
I want to know if I will obtain the same sonics from my monoblocks with the new TS KT120s as with the new TS 6550s.
Thanks.
keep on truckin
joe
