Soundcraftsmen EQ slider replacement
I'm hoping a new slider board will fix the issue I have with my SP4002: With each slider set exactly the same on each side (A & B), the stereo image is not centered. It's as if the balance control is at 10 o'clock. I end up with the Channel A zero gain control down below center, and the Channel B zero gain control up above center.
Attaching a photo that illustrates
Make sure it's not your input source, swap left to right and see if the problem switches with it.
Attaching a photo that illustrates the scenario...
That's an interesting issue. I'm not sure why it would happen, but there are gain settings for each channel inside. I try to set them so they are exactly the same voltage in and out. It can be done with an average multimeter and sine wave source. But... the adjustment for the LED comparator light balance ends up being a touch off the dial to get them balanced. The last one had to be .995V output at a 1V input for the lights to balance out. It is common. I may take a closer look at that circuit in the future to see what resistor needs to be changed to get the voltage exactly equal and have the LED balance in the middle of the potentiometer range and not the end.
it's possible that it's just a dirty control(s)
You may also want to recap it. The bipolar caps in the signal path can do the same thing. I've seen it more than once.
It may be a bit before I can fully fit one of those boards, but I'm pretty confident they will work. I have a couple amps to go through first, one being a large custom project. I'm making a Soundcraftsmen RA5002. That model number doesn't exist, but I'm adding the extra transistors and correct changes to make it the heavy duty RA version. It will also get one of my custom input boards, and other upgrades.
I did in fact recap one of my PE2217-Rs that has the same issue, but it didn't help. I realize it doesn't necessarily mean a recap won't fix the SP4002. But for now, I can live with the issue as long it sounds good... which it does. It's just that I would prefer it to work the way it's supposed to work. :)
The RA5002 sounds like a very cool project!
I have a DC4415 EQ I've been waiting to go through. It's a 1/3 octave EQ with 44 sliders on it. I'll have to measure the spacing on that one, it might be too close for the new sliders to fit.
I found a DC2214 face-plate I had laying around. It is a different size board, or possibly two boards. They aren't on it anymore. I doubt I'll make boards for that model.
Forgot to mention that both PE2217-Rs that I own have the same issue, each to a differing extent.
I never had this sort of issue with my old SP4001 back in the day... of course it was new at the time, and all my current Soundcraftsmen gear is very vintage!
As a Soundcraftsmen owner for nearly 50-years, I can say the only issue I ever sent anything back to Soundcraftsmen over was a channel output imbalance on my original PE2217 (bronze face). Repaired under warranty, SC said they replaced the volume control. Problem was in my subsequent listening and measurements, the repaired unit was "better" but still not perfect. (The original wood case was damaged in their return and replace with a vinyl one from them, for which I have never forgiven SC!)
Since then I skipped a SC generation and replaced it with several different later model SC pre-am-EQ units and the PE2217 has sat on a shelf. That includes some DX4200 which worked perfectly before I replaced them with Pro-Control-Four and Pro-EQ 44 which have been in two systems and remain there today. The imbalance hasn't reared its ugly head since the 2217 era. Here's today's living room system bi-amped for my JBL 4345s. I do have two SC Pro-Power-Fours I could use but I just prefer the Crowns. To their credit, the sliders on the Pro-EQ 44 have always worked with silky smoothness.
I installed the new slider board in an SP4001, the SP4002 is next. This one also got new caps, ICs, and paint.
I'm most of the way through a DX4200. All new sliders, caps, and op-amps. I just have to finish painting the panels and test it all out.
I also went through and did caps and sliders on an RP2215R. Also turned out well. I do think the new boards and sliders provide better shielding. Everyone I have done so far has exceeded the S/N rating, and have not needed extra work. That wasn't always the case before.
