Took a chance recently on a SP4001 I saw on fleabay. Advertised as "powers up, no further testing." It looked good cosmetically, and the price was right so I pulled the trigger.Forgot to mention that both PE2217-Rs that I own have the same issue, each to a differing extent.
I never had this sort of issue with my old SP4001 back in the day... of course it was new at the time, and all my current Soundcraftsmen gear is very vintage!
Looks great. How are the sliders?Took a chance recently on a SP4001 I saw on fleabay. Advertised as "powers up, no further testing." It looked good cosmetically, and the price was right so I pulled the trigger.
I'm happy to say it turned out to be a real bargain! All it needed was new 1000uf, 35V power supply caps to fix a low level buzz that was audible with no signal applied. I had the caps in stock and the repair took all of 30 minutes. So glad I rolled the dice on this unit!
Thanks! The sliders are a little sticky, but still quite useable.Looks great. How are the sliders?
Thank you!Wow... that DX4100 looks amazing. Well done!
Job well done. Nice find on those slider caps too.Here's a PE2217 I just finished replacing the sliders on using Bourns 45 mm faders, with the kind guidance of @Racingh11 . The replacement involved making two brackets from half inch aluminum L-channel, mounting the faders to the brackets, and then mounting that to the chassis using half inch standoffs. It's tight... "file to fit, paint to match" as my engineering mentor used to say, but these do in fact fit in the space available. It may be possible to spin a 0.032" PCB to accomplish the same thing but for a one-off, it made more sense to do it this way. Generic fader knobs from Amazon (link here) fit the faders perfectly. I did have to knock off about 1/8" or so from the level set knobs with a lathe, but overall it looks pretty close to stock.
I still need to sniff out the test lights in the right channel, which aren't coming on, and re-rework the power supply caps as they are a little low on the voltage rating for my tastes. There is a little noise in the eq switch as well I think. But, the phono pre in this thing really sounds nice, as does the very minimalist line stage. This will be paired with a PM860 I restored earlier this year for a dear friend and mentor.
View attachment 3529853View attachment 3529854
Nicely done! That looks fantastic!Here's a PE2217 I just finished replacing the sliders on using Bourns 45 mm faders, with the kind guidance of @Racingh11 . The replacement involved making two brackets from half inch aluminum L-channel, mounting the faders to the brackets, and then mounting that to the chassis using half inch standoffs. It's tight... "file to fit, paint to match" as my engineering mentor used to say, but these do in fact fit in the space available. It may be possible to spin a 0.032" PCB to accomplish the same thing but for a one-off, it made more sense to do it this way. Generic fader knobs from Amazon (link here) fit the faders perfectly. I did have to knock off about 1/8" or so from the level set knobs with a lathe, but overall it looks pretty close to stock.
