jrgood0852
I'm loving it so farIt's funny how there are different power ratings for several amps that have the same circuits. This one will do much more than the 100W per channel 8 ohm rating.
Very similar sound, but I give the edge to the SoundcraftsmenI'd love to hear how you think your DH-220 compares to your new Soundcraftsmen. Be explicit with any similarities or differences. They should be very comparable mosfet power amps in many respects.
That's freaking awesome. I have 12 other amps and I must honestly say the one that comes closest to me in sound is my fully restored Son of AmpzillaI sold my big McIntosh amp and replaced it with a restored Soundcraftsmen MA5002. Maybe not a pretty, but it sounds every bit as good to my ears.
Nice stack, send the EQ my way if you want new sliders!I sold my big McIntosh amp and replaced it with a restored Soundcraftsmen MA5002. Maybe not a pretty, but it sounds every bit as good to my ears.
I have a few of the EQs, and preamps with EQs.Nice stack, send the EQ my way if you want new sliders!
My personal unit is a DX4200, but I have several different models that are restored.I have a few of the EQs, and preamps with EQs.
CX4100 has the CX record capability, and the DX4100 uses that switch spot for another loop I think... Otherwise they are the same preamp and EQ.I have The CX4100 and DX4100, not sure what the differences are.
My favorite best bang for the buck out there. EQs are not really my thing, but I have a few.The Soundcraftsmen is back in my system and staying. I hear every nuonce of every instrument & vocals. Absolutely my fave.
I've put the 2 pieces together with Crazy Glue and Will attempt to put it back over the resistorOk guys. So I just had to go inside and take a look around. Everything looks pretty much original. The filter caps are silver, so assuming they are also. I noticed 2 pieces of a ceramic cover which upon further investigation came off of a 5 watt resistor from one of the boards. I'm guessing from age. So my question is. Is it anything to be concerned about? The resistor it came off of looks fine, and the amp sounds perfect. Thanks
Upon further investigation, it would be WAY too much of a pain to try to glue it back. It's in an almost impossible spot to get to. Looking carefully at the resistor, you can see some residue on it from the ceramic cover. It has to be due to age (42-44 yrs). I think I'll just leave it alone and use it. Any foreseeable issues? ThanksI've put the 2 pieces together with Crazy Glue and Will attempt to put it back over the resistor
