Spade adapter question
caxton1476
I installed spade adaptors on the screw down terminals of my Realistic STA-18 receiver. The body of the adaptors rests against the chassis of the receiver - see pic. Is this a problem?image.jpg
I installed spade adaptors on the screw down terminals of my Realistic STA-18 receiver. The body of the adaptors rests against the chassis of the receiver - see pic. Is this a problem?View attachment 3834749
Could be if the + terminals slide down and make contact with the chassis. Perhaps a couple of layers of electrical tape under the terminals, over the chassis lip but not covering the + and - designations.
To be clear, all four adaptors are in contact with the chassis. Metal on metal.
In most cases the negatives are common with chassis anyway. But, since I don't know the specifics it would be wise to insulate all of them for good measure.
Or, as another has alluded to, do it in a different manner where there just isn't as much of an accident in the making.
Maybe a nonconducting collar between the adaptor and the chassis? Like a plastic or rubber washer?
Anyways I removed them before reconnecting my speakers, which are diy rigs from the early sixties with coaxial Utah drivers. Source is a cheap Bluetooth thing, 1Mii brand. It sounds so nice. This is my home office setup, where some nights I enjoy a little scotch.
Yeah, I would think some very thin inert washers or liquid electric tape or something like that would be good as an insulator.
I fought many a screw terminal. Then I bought a 100pk of #6 10ga spades. Fits the old stuff, no risk of shorts.
There's many right ways.
I did this when I converted to 10ga speaker wire many years ago. I used them previously with the smaller gauged wire too. Just easy to do. The frustration factor of bare wire on a screw was too high. lol
I don't like the non-flexible ones, seems like a good way to rip the terminal strips apart. I have these, bought cheap on amazon
the set is 11 bucks. Flexible, insulated, fits screw terminals nicely.
I started using these about 6 months ago with the idea that I'd like to switch out receivers occasionally, but I haven't really done that yet. My only gripe is when you use both A & B outputs it gets a pretty tight; especially in my situation where the receiver is on a counter and the wires have to sit on it rather than dangle from the back of the receiver over a shelf or back of a rack.
But there are definitely many ways address different situations.
Using forks crimped directly on the wire would be ideal, but i swap stuff around and my gear has a mix of terminal strips and binding posts. Adapter between them is for convenience, even if adding more connections is sub optimal
image-jpg.3834749
Will electrician's tape fit under the adapters?
