Speaker ID
Jenkster
When I had talent
My son found these speakers in a storage unit. I believe they are Infinity’s but not sure. Any help would be greatly appreciated,
Thanks!
Infinity Quantum 3. Well worth fixing up. Plenty of info on here and elsewhere on the Quantum series.
Many thanks! Looks like a definite project. The cabinets are in pretty good shape, not due about the drivers. Obviously the woofers need work.
Is that the way they were made with the overlapping tweeters?
Bobhorn
Nice cabinets
No, They are not supposed to be overlapped.
Someone was messing with them or replaced them.
It's common to blown them out.
You can replace the Diaphragm's but you need a He-Man Gorilla grip to pull it off!
There are quite a number of AK threads that describe a need for a robust amplifier to drive the Quantum 3 speakers. The general consensus is that you need a high-current, high-power solid-state amplifier that is highly stable down to 4 ohms and lower.
Like many vintage Infinity speakers from the late 1970s, the Quantum 3 features a complex crossover network and a specialized 12-inch Watkins Dual-Drive woofer. This combination causes the speaker's impedance to drop to dangerously low levels at specific bass frequencies. If paired with an underpowered or unstable amplifier, they can trigger the amp's protection circuit or cause it to overheat and fail—earning the Quantum 3 speakers the nickname "amp killers".
