XplicitActs
I was thinking the same thing. Even the little bit of humidity in the house will create surface rust. Use a gloss clear coat.Better clear coat them before they rust.
Slight tilt, just use a spacer placed to the bottom front of the block.That's a great idea, was looking for stands for my big ADS L620's. Off to home depot tomorrow. I need to figure a way for a slight tilt.
Good PointMaybe it's just me, I found the topic heading a bit um, err, wth?
Who puts floor standing speakers on stands.
Oops. I didn't see your clarification post before i mentioned sub woofers LOL. Hope i didn't hit a nerveTo clarify what I posted earlier, if a speaker is meant to be placed on the floor then it's a floorstander/tower speaker.
Speakers with built in stands included.
If a speaker needs to be placed on stands then it's a stand mount/bookshelf speaker. Even if the stands are 6 inches tall.
Back in the day some rather big-ish speakers were called bookshelf speaker.
My Infinity RSM's were in that group.
But like I mentioned, maybe it's just me.
And don't get me started on vinyls and "sub woofers".
Oops. I didn't see your clarification post before i mentioned sub woofers LOL. Hope i didn't hit a nerve.
LOL. I am using an EQ on my current "A" system (Yamaha CT810 int amp) however i have a Yamaha CR840 "B" system set up right beside it, each driving multiple set's of speakers in the same room, including shared mains on a switch. When i have the CT810 / EQ adjusted to what my ears find most enjoyable, i listen, then quickly switch to the CR840's, un-equalized signal, sometimes even with the same piece of music. So, after all that Mr. Wizard maneuvering, i have found that sound i hear when i switch is almost identical. Maybe im just trained to enjoy that Yamaha "Natural Sound" but EQ's, i can take them or leave them. I'm going to adjust to what i like either way. So you go Rebel.. add some strobe lights and kick it up.Nope.
I meant the kids who call the biggest driver, even if it's only 4 inches, a subwoofer.
Besides having my floorstanders *slightly* elevated (down from the 6 or 8 inches they were previously elevated) I am also using a subwoofer with them.
*gasp*
Even worse, I also use an EQ.
I am such a rebel.
looked at the Sound Anchor website. That's what i am talking about. Very good suggestion. Thank you.Check out Sound Amchors too. They often show up second hand, just have the measurements of your speakers to compare with the top plate dimensions of the stands you may come across. Height too, you don’t want them in the ceiling. Try the marts, audiogon and the ‘Bay.
Sounds cool any pics?I bought 12" table legs at the big box store, had a couple of pieces of white birch cut, stained it all, and they're good to go. Cost under $75 for the pair.
If they are truly floor standers why would they need stands? Posting pictures of large bookshelf speakers on stands has nothing to do with actual floor standers.
