At what point was I irrational? I certainly didn't insult your intelligence or your methods. I disagreed with you.
My "theories" are based on 35+ years of experience as an electrician, following the same standards used by competent manufacturers and technicians.
When I wrote, "spring clips deform the wire strands, thereby increasing resistance." I was referring to the same kind of deformation that you can see here:
Picture by brunomarcs
Those bite marks were caused by spring clips. The damaged area is a source of increased resistance because the conductive area of the wire has been reduced.
Damaged wires don't conduct signal or voltage as well as undamaged. Spring clips also tend to splay the strands of the wire out,
only making direct contact with a few of them.
Notice how the wire strands in the picture are seperated? Splayed wire strands don't carry signal or voltage as well as tightly bundled (or tinned) stranded wire.
That's all speaker wire is doing, carrying a signal and voltage.
For your entertainment, I can offer this link to the industry standard for electrical wire assembly.
http://www.ipctraining.org/demos/pdf/drm-wha-b.pdf
If this doesn't seem rational to you, then please carry on relying on your experience.
I'm here to discuss and learn, not to change your religion.
