I don't trust Sams measurements? estimates? guesses? of output transformer impedance. My own measurements haven't agreed in some cases.
I appreciate all the responses - both here and as a few of you did, also at DIYA. No, I do not have an existing unit - I'm searching for the info to consider building a clone using new transformers [Lundahl perhaps] and premium components. This is after assembling a DG board set ST-35 and being blown away by it in comparison to Mac vintage - mid-60's SS that I still enjoy also. In fact, the pre for the 35 is a Mac C24. I'd now like to explore additional EL84 amps and the Pilot seems to be well thought of. Inputs so far are mostly a bit discouraging, but I do not for a moment doubt their accuracy, i.e unless you have a 2 channel scope and signal generator plus knowledge to understand component swaps to offset not having explicitly the Pilot OPTs then don't bother. Others were a bit more encouraging on not every amp out there is perfectly circuit tuned.
So I'm not sure - to use the Dyna ST35 transformer set as reasonably noted here, I might as well just build another 35 and try a custom chassis with PCB mount spacing wider to allow coupling cap upgrades [Miflex maybe] and splurge on NOS tubes - this is for a 2nd system if you're wondering why not just mod the first one. Kits are are rare these days - the 50's are long gone - but it may simply take stocking a better equipped workbench to try the DIY route.
Have you compared your rebuild to the stock amps? Was it worth it? Do you have a pics of the inside and/or schematics for what you have done? Tks.Just for the sake of EL84 conversation, you might also consider the Heathkit UA-1/2 and EA-2/3. These are UL PP EL84 amps and they can sound very nice with some restoration and upgrades. I have a pair of EA-2's, which originally were integrated amps, that I converted to be power amps. They were rat rod amps that I got at auction. I removed all the preamp parts, installed a new blank face plate with just a lighted power pushbutton and rebuilt the amp sections from scratch. I added a choke in the supply, installed a better RCA jack on the rear panel, restuffed the can cap, added tip jack test points for monitoring the output tubes, and added an AC balance pot in the phase splitter. I think they sound quite good. I also have an SCA-35 with the full PC board set from DaveG. It's a great little amp, but think I like the Heath's a little better. I prefer separate power amps to integrated's as a rule.
John
Got it, tks.I have heard restored UA-2’s and they are the same as these. I made my EA integrated amps into UA power amps. They use the same transformers.
