Sta-2100
No, its on my list of things to get.
Is it ok to use it if that fuse is bad?
The other fuses look fine.
What do you mean the fuse is heavy enough?
Ok...LOL...I did not know that part. :scratch2: I wish I had more time but I don't right now. If all of the lamps are out but everything else seems to work ok, I would still suspect a fuse on the power board because it has happened to me but the guys on here who know a lot more than I do may have other input.
It looks like F3 (2.5A 250v) on the power board protects the light circuit. If you do not have a meter to check it or a known good fuse to swap, I am not sure what else to tell you to try. This is the fuse that I blew during my cleaning and lamp replacement. It is where I would start troubleshooting (if I knew that I had good lamps to begin with and that I had power).
...and I would still replace that main fuse in the back if the glass is discolored.
I got the service manual. I'll get the fuses when I can.
I'm still open to ideas.
Ok, I got a 32v 10 amp fuse for the back. That should work right? The prevous fuse in their was a 10 amp 32 volt one.
Arg, the fuses i picked up said 10amp 250 volt wtf.
Ok, I replaced fuse F3 now lights work, next step is to replace the stereo light and aux light, this will be tougher. Also need to find a new knob.
Check the switch again , plus see if there are some wires touching were they shouldn't be .
Barney
